Steven, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Yes you can but you need the internet to watch it. Without a internet connection the only option left would be to view it through your phone. Again though your phone would have to have web access.
The short answer is yes, you can watch over the air DTV programming on your tv without buying another DTV tuner. There is one built in to the tv. You will need some sort of antenna and then
you will have to scan the channels. But the tv is NICE and you will do just fine.
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Depending on how far you are from the broadcaster you can try Rabbit ears or and outside antenna.. If the set is more than two years old you may need a digital converter after Feb 17th
