Question about Acer Aspire One AOA150-1983 Notebook PC
System will not boot past the windows startup screen. I have tried to boot in safe mode but no joy. I have also tried to boot using ERD commander on a flash drive to try and salvage my files but once again...no joy. Any suggestions on how to recover the files?
  • brandyb35058 Jul 19, 2009
    I am not sure I understand. This laptop does not have a cd rom and I cannot seem to get it to boot from the flash drive. Any ideas?
  • 41 Answers
When you reboot you need to press the f8 key. Is that what you tried ? Try tapping the f8 key every second or so until you get to the startup choices. once there choose command prompt and then run chkdsk / f.
don001996
Posted on Jul 19, 2009
    Sniper:
  • 59 Answers
To recover your file you can run windows repaire installation. it is not delete your data.
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
My asus u52f-bbl9 doesn't want to move past the boot screen
Have you tried booting into Safe Mode?
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
If all fails Sounds like your operating system needs to be reinstalled or you can do a system recovery to set it back to when you first bought it.
Apr 09, 2012 | ASUS U52F-BBL9 Laptop
XP Home Boot Problem
Restore Computer:
To start System Restore using the Command prompt, follow these steps:
  • Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  • Use the arrow keys to select the Safe mode with a Command prompt option.
  • If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  • Log on as an administrator or with an account that has administrator credentials.
  • At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  • Follow the instructions that appear on the screen to restore your computer to a functional state.
  • After restoring. restart your computer and use system utility tool like Reginout to fix coorupt windows files.
Dec 27, 2011 | Computers & Internet
Win Xp sp2. Continues to reboot on startup. Cannot access safe mode. Have substituted RAM, power supply, hard drive, disconnected dvd burner and floppy, flashed the bios. No improvement. About to...
HI
if you have ERD commander then you can restore your system and taking backup of your drive data...
ERD is a bootable Disk which is boot just like a O.S...
and if you don't have ERD try to format your system and install new windows....
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Gigabyte GA-K8VM800M Motherboard
ML150 G3 server starting hp proliant screen after it is going to automatically restart, what can i do?
check ram
try hitting f8 on boot see if you can get into safe mode?
if u can then try running chkdsk /f in dos mode
if that doesnt work run a scan in safe mode
if cant get into safemode at all,get a bootable erd commander 2007 and boot with cd,choose your windows installation if you see it and use restore option,if you dont see windows installation at all try backing up ure data if necessary using usb adaptor for hard drive n copy data to other pc nad re install windows
May 05, 2011 | HP Compaq ProLiant ML150 G3 Server
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
MY toshiba 4300 was working untill i tried to install internet explorer 8 then i prompted me to shut down and ever since then when i turn it on a blue screen pops up saying boot volume or somthing i need...
Hi, yes. Download a program called ERD Commander 2008 or 2005 and make a bootable CD. I think you will download an ISO so you need Nero to burn it on a disk. Then boot from it (on the toshiba 4300) and once you are using the ERD commander, look for system restore, and it's the same as the Windows system restore. Choose a day before you downloaded the Internet Explorer and see if it works. I hope this helps. Don't forget to rate and provide positive feedback for our fast-free response today. Thank you :D
Apr 29, 2010 | Toshiba Satellite 4300 Notebook
Forgot administrative password how can i solve problem???
Well if it's windows xp, then you could try going into safe mode by pressing th F8 key at startup (before the windows XP splash screen), then trying to login under administrator. If that doesn't work, or if you have Vista, you will either have to try to get a password cracking program (like Ophcrack, or ERD commander 2007). Otherwise, you will ahve to backup and reinstall your operating system.
Oct 04, 2009 | Acer Computers & Internet
It starts with the lenovo screen and then goes to the Windows XP screen but it goes back to the Lenovo screen. What can I do so I wont have to restore my system again?
ok, press f8 key as the system is booting up, this will put you in safe mode,
if the system boots okay goto command prompt mode and type chkdsk /r to repair any files etc ,
Try booting up again, if the problem is the same then it a startup file that need repairing so goto safe mode, command prompt type bootcfg etc and try repairting it that way, us e the help command to point you in the right direction.
Regards
GeWiz
Oct 01, 2009 | Lenovo 3000 C200 Notebook
My acer aspire 3000 can not finish booting
you must try to open your system in safe mode
to start your system in safe mode
pressF8 when the BIOS screen appear
from there you are able to find the application causing trouble in startup.
you cane also try system restore in safe mode
for system restore take help of windows help and support
Apr 23, 2009 | Acer Aspire 3000 Notebook
Acer Aspire One AOA150-1983 Notebook PC Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
