CarGurusMar 5, 2013 - My Hyundai Sonata won't start, everything comes on when the key is turned but no ... it is in park and until I jiggle the shift until the light does come on it will not start. Was in ... My 2009 Sonata has been "perfect" with no issues.
remove 1 spark plug wire from the plug. Find a socket that fits the spark plug and connect it to the socket wrench. Put the socket on the spark plug and turn counter clock wise until the old spark plug is removed. Check the gap on the new replacement plug ( make sure you have the correct plug first). Put the new spark plug into the hole that the old 1 came out of and turn clockwise by hand making sure it is in straight, then tighten it clockwise until tight.( WARNING: DO NOT OVER TIGHTEN THE PLUG OR YOU WILL BREAK IT). replace the spark plug wire. repeat the process with the other 3 spark plugs. Start the vehicle. If you are replacing the wires, take off 1 wire at a time, match up the size and replace the old with the new.
Autozone.com says that for this vehicle the firing order is 1-2-3-4-5-6 and the set-up is 2/1 4/3 6/5 meaning that the #6 cylinder is far right on the back. It goes #1 #3 and #5 in the front and #2 #4 and #6 in the back.
