Question about Nokia 6233 Cellular Phone
No drivers are installed for this device.
When i plug my usb in on any computer with different usb leads it displays No drivers are installed for this device.
  • Nokia Master
  • 805 Answers
Format ur phone
Posted on Jul 19, 2009
Computer is not reading it now
plug it in and check under device manager if it is listed, it may show up with an error as unknown usb device, if so un-install the drivers reboot and plug it in again, if same error check with different lead. if still same errors download drivers and reinstall. if non of that works you may have a faulty conection socket.
Aug 29, 2014 | Kurio Touch 4S Handheld
Infitek MP4 8GB player - No Drivers??
What windows version are you suing?? Try going to device manager and look for a root hub there or any usb device that has a exclamation mark then right click on it select update driver and let the wizard search for the driver.
Hope that helps..........
Jul 31, 2008 | iLO (2 GB) MP3 Player
Maxtor basics 500GB power light flashes quickly
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 16, 2012 | Maxtor Computers & Internet
WD 320G external drive-- power lights on but drive did not spin and or appear in the icon bar. Not able to access the drive. Tried unplugging and plugging back in several times--does not seem to work....
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps you
Oct 30, 2011 | Computers & Internet
Canoscan LiDE 100 on WinXP loaded drivers+software from disk
Have you tried going to the Devices Website for any CURRENT SOFTWARE UPDATES/DOWNLOADS?
Jul 05, 2010 | Dell Inspiron 1525 Laptop
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
I bought a new Sandisk Fuze 4Meg MP3 yesterday from Best Buy. Hooked up to XP SP3 USB port which functions with other devices. Display screen says "connected". Opened Win Media Player V11. Opened "My...
Hi.
The unit is new, and does not connect to a computer. Test it using a different computer, if it still does not connect, then call Best Buy and have it replaced.
Regards.
Nov 15, 2009 | SanDisk Sansa Fuze MP3 Player
Whenever i am connecting the lg lxu-800 usb modem in my computer it is asking for the device driver software.Although i have the cd,still it is not getting detected.
  1. Disconnect modem from computer by taking out the usb lead from computer
  2. insert modem cd in cd/dvd drive and run install
  3. Install the driver from the cd
  4. follow directions onscreen the restart computer if necessary
  5. plug modem back into usb port
  6. now when windows detects it it will find the correct drivers
Welcome
Jun 22, 2009 | Computers & Internet
Unable to connect via Data Cable with Computer (OS = Windows XP)...Error Displayed Unspecified USB DeviceTried to Install Nokia 6100 Cable (Modem) Driver Downloaded from Authorised Nokia Website But...
this is a problem with your computer did you get a disk with the lead you need to tell the computer what you are plugging into your comp i had the same problem when i plugged a memory stick into my usb port so i had to search the net for the software and even when i had the software only one of the usb ports would let me use the device the other port was telling me to remove the devide hope this is some help dont know where you can get the software for your device my comp gave me the options of letting windows search the net for compatable software and it found it for me and now i have no probs
Nov 22, 2007 | Nokia 6100
Nokia 6233 Cellular Phone Logo
156 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
