Question about Sony PlayStation Portable (PSP) Console
My PSP won't read the disc
Have tried numerous discs and still reach the same problem.
HELP!!
This is probably because your lens of the UMD reader is scratched or damaged.Also check if there is any moisture in your psp.
The best thing to do is call sony for a replacement or repair.
Posted on Jul 19, 2009
The disc cannot play reason code is invalid
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
MY PSP HAS STOPPED PLAYING DISC, IE FILMS, YOU PUT THE DISC IN CLOSE UNIT YOU CAN HEAR DISC SPINNING BUT NOTHING ELSE, PLEASE HELP.
You need to send the psp in for service as the drive is malfunctioning. There is a problem with the lens of the disc drive when trying to read the discs.
Feb 27, 2011 | Video Game Consoles & Games
MY psp is unable to read any UMD discs. I tried two different discs and the psp said, "The disc could not be read". The psp games were working before on my psp but I don't know what happened to...
Did you have a firmware upgrade? if you can detail your current firmware I might be able to help you. There are higher custom firmware (CFW) that has known issues with UMD reading. Don't worry, it's about your UMD, you can even try the same UMD to your friend's PSP and Im pretty it will run. It's your firmware that needs to be changed. However, you may need to downgrade first before upgrading to a new firmware again to solve your problem. Please get back here when you have the details...
Feb 23, 2011 | Sony Video Game Consoles & Games
Everything on the PSP is working except the UMD drive. The motor is working and the laser light comes on but it says it can't read disk. Whtat can I do to fix this?
This is usually a problem that comes up when you are trying to play a disc that is badly cracked or is probably having a very rough face and as a result, the data on it cannot be read by the lens of your psp UMD drive.
The best thing to do is to try loading this disc on another psp and see if you get the same result then you can be certain that the disc is damaged or you could try another disc on your psp and see if it works, then you would be sure if it is the psp or the disc that is damaged.
hope this helped you?
Dec 25, 2010 | Sony PlayStation Portable (PSP) Console
Does nor read discs
the psp has certain conditions that needs to be met before it can read discs, for example, the region code of the disc must match that of your psp.you can check the region code on the pack of the disc you are trying to play and check the region code of your psp on the carton or better still, read the manual throuroughly to know the discs which are supported..hope this was helpful to you?
Oct 19, 2010 | Sony PSP (Piano Black)
Psp will not read discs
try clean the disc or putting the disc in a new cover
Jul 22, 2010 | Sony PlayStation Portable (PSP) Console
My son's psp (the older fat version) has stopped reading discs
Not sure is this actual PSP or play station. If it is Play station It is very possible that there is problem with laser that reads disks. Try to by PSP cleaner and run it and this might fix the issue.
Dec 29, 2009 | Sony ACY-BR81/OB
Psp wont read discs
try cleaning the inside of it... maybe its just dusty so dust accumulates heat.. hence overheating the lens and watever's inside the psp.
Jul 21, 2009 | Sony PlayStation Portable (PSP) Console
Psp wont read the disc unless you hold the door shut w/o ...
If you dropped it, then the reader may be a little messed up. If the case around the disc is popped open a little bit, closing it all the way might stop the disc from spinning, resulting in not reading the disc. The only thing I recommend is to contact Customer Support on the Playstation website. They might be able to help you fix the problem or have you send it in. www.playstation.com
Apr 29, 2009 | Sony PlayStation Portable (PSP) Console
Psp
Buy a UMD disk cleaner this may help
failing that make sure system plays other discs or that the disc you are trying to play, plays in another PSP.
If it plays other discs fine its not the PSP its the disc.
If it doesn't then its the PSP that will need to be sent away for repair.
Dec 15, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
267 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
