Question about Sharp AR-5316 Advanced Digital Imager Copier
Error Code H2
My ar 5316 copier is displaying H2 and it is not able to make any copies
  • 22 Answers
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Posted on Jul 24, 2009
    President:
  • 3,085 Answers
H means heat. You need a new FUSER.
Posted on Jul 19, 2009
    New Friend:
Write your answer... It worked thanks alot.
All I did was to press the
#,interrupt,c,interrupt in sequence. The
display then went off.
I then press the numeric keypad 1,4 and
start botton in sequence. It's fine now.
A big thanks.
Posted on Sep 17, 2015
2 Suggested Answers
SOURCE: Sharp AR 5316
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
Posted on Dec 03, 2007
Pls help for sharp copier AR-5316 error code 2-H
H2 signal is thermistor open
check the harness and the connector between the thermistor and the PWB use TC 14 to clear the self diagnostic display.
Oct 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Printer message error H2.
Fuser problem, Check to make sure fuser installed and connected. Use Sim 14 to reset. Hold the light expouser key until all lights flash and - - shows on display then enter 14 and press the copy button. Machine should restart.
Aug 30, 2010 | Sharp AR-5316 Advanced Digital Imager...
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
What cld cause sharp 5316 indicating an open thermistor
NO! 500 copies cannot spoil a copier.It should last for 100s of thousands of copies.Try opening and closing the front door.That will sometimes reset some error codes
Apr 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR 5316 is blicking h and then 2 please wat do i do...and pls how many copy can i make wit it in a day
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Sep 04, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
549 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
