Question about RCA HD56W66 56" HDTV
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
When I turn the tv on, the screen is distorted. All 4 sides of the tv picture are curved inwards causing the picture to be blurry. There is also a red and a blue line that appear on the top part of the picture that are also curved. Please help.
Thanks
    Genius:
  • 1,030 Answers
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Posted on Dec 08, 2007
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Descending curved line on screen
if the tv has a portal on the side open it up and make sure the screen is not out of it's track, don't set anything on top of the set it could make it happen also
Apr 13, 2007 | Samsung HCN653W 65" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA HD56W66 56" HDTV Logo
657 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
