Question about GE Monogram ZISS480DRSS Stainless Steel
Sounds familar. Refrig side keeps going down to low 20's no matter where we set it. ????
  • GE Master
  • 1,606 Answers
You could have a bad damper control (cuts the air off to the refrigerator section) , a bad #1 thermistor , a bad HMI control asm . All could be checked using the HMI as a test board .
Posted on Jul 19, 2009
Kenmore Sideby side refrig 106.53242300 freezer
sounds like a bad blower motor . replace it . the brg must be bad . mm
Feb 04, 2010 | Kenmore 52342 / 52344 / 52349 Side by Side...
I have a side by side refrig/freezer and the water dispenser thru the door keeps freezing up , even tho I have temp. turned down as low as I dare.
it sounds like you need to replace the gasket around where the Ice comes out. the outside and the inside air are making it freeze up
Jan 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a GE profile side x side refrig. The
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
Oct 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fan cycling low and high
The freezer fan slows down due to the refrigerator section being at the desired setting but the freezer section still needing coolant . If the refrig section needed more coolant , the fan would speed up , forcing more air into the refrig section .
After replacing the heater , it could be in the defrost cycle . The thermistors tell the main control board , " hey , we're freezing , turn on some heat " , in which the heater comes on and defrosts the coils , until behind the rear freezer panel , can get up to 140 degrees . As it gets this hot , the frozen food in the freezer , is what keeps the freezer cold . After defrost , the fan comes on and blows the residual heat into the refrig sectio , until the coils get cold again . So , if the refrig section warms up temporarily , it's normal .
Sep 06, 2009 | GE Refrigerators
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Never shuts off.Too cold
Try defrosting.
if you can move everything out unplug ,turn it off w/ doors open 6 to 12 hrs this will free up any clogged tubes. Set it at a low setting and keep an eye on it, If this doesn't work your thermostat may be going out.let me know.Good luck.
Len West
Feb 16, 2009 | KitchenAid KSRS25IL Side by Side...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
WARM REFRIGERATOR
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE Monogram ZISS480DRSS Stainless Steel Logo
228 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
