I have a samsung le40a556pif television that wont start can you tell me what i need to do to get it to work
Main Board for a UN55b7000wf samsung LED TV
The BN97-03189B board is formatted for the screen size of your tv. You would be trying to install a board meant for a 46 inch tv into a 55 inch tv. It just wont work.
Aug 19, 2016 | Samsung Televison & Video
Samsung tv un50eh6000fxza...has standby power but some times takes several tries to start. When it starts led flashes 6 times. When it wont start led flashes 2 times after 15sec from pressing power.
This is usually caused by some tubular capacitors that have gone bad. You can tell visually by the fact that the bad ones have started to swell up. You can check the value for voltage and microfarads and buy replacements at Radio Shack or similar electronics store. While the microfarad capacity has to be the same, the voltage can be the same or higher.
Mar 09, 2015 | Samsung Televison & Video
I have a samsung dv448aew it powers up but wont start it shows error 1 door open
need to check the door switch and thermal shut off fuse, with a multi meter for continuity.
May 21, 2014 | Samsung DV448AEE Electric Dryer
Where can I get parts for my Samsung Plasma screen its 5 years old and both upper and Lower Y boards have gone. Samsung wont supply me with the parts and the service centers wont supply me with parts...
First you must list exact model number and if possible module part number listed so that one of the techs of this "forum" may even be able to furnish you the parts needed.
Dec 29, 2010 | Samsung Televison & Video
Samsung 5075s- new bulb, and I ordered the ballast to put in- Got information that it could be the power supply. I've seen a few than pass "dirt" power to the ballast and damage it. Does this mean that I...
H I am Vortash .. It is possible that it is not the ballast at fault but the unit not sending the correct signals to tell it to ignite the bulb , it could be the power supply and you may have suffered a power spike that damaged your system , however if you are not an engineer I can tell you that there are a number of reasons why the ballast wont start from a simple bad connection on a plug to an IC not functioning correctly .
So you may save yourself time and money if you take it for a free estimate as you could be spending money on things you don't really need ?. .. regards vortash
Mar 30, 2010 | Samsung HLT-5075S Television
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or...
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Sep 04, 2009 | Samsung PPM42S3 42 in. Plasma Television
Hi i just a new samsung 40" 630 kcd tv. i was wonderingi s it possible to make it work at 1080P 120Hz right now it shows as 1080i at 60hz. I have a Verizon HD box
hi just to let you know the samsung 630 is a great tv i like it alot so im gonna try to tell as much as i can right now nothing is playing in 1080p so you will not have to worry about that but when it does start to you will be ready your tv is running at 60hz what the 120hz does is just add extra frame you really wont see the difference only when you watching blue-ray
Jan 10, 2009 | Televison & Video
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
