Question about Sanyo Televison & Video
2 AV inputs, only 1 works at a time.
I just received a Sanyo 51cm flat screen CRT TV (not sure of the model number). It has 2 av inputs (1 rear, 1 front) and so I have plugged in my dvd player to the rear and set top box to the front. However, the TV only seems to have 1 AV channel. The set top box is showing through this channel, but the only way I can get the dvd player to work is by unplugging the set top box from the front inputs. Any idea if this is fixable so that I can switch between them without having to pull out cables every time? Thanks.
  • Sanyo Master
  • 1,527 Answers
Hello try using a scart block at the rear good luck
Posted on Jul 19, 2009
I have a sylvanaia tv model srt2232x and I'm
Hi. Don't you have an AV button on you remote ? If your game is connected to an AV input, try to use the channel (-) buttons on your TV. Numbers below 1 mostly give access to AV1, 2 etc.
Make sure the AV input can work, simply by connecting a DVD player to it.
Oct 17, 2014 | Televison & Video
Rear jacks
Connect the device with rear sockets, and select the input. As there is rear jacks to your TV AV-1 & AV-2 selection must be there. Enter into its Menu option, surf through, come to input selection window. and select proper selection here. Switch ON both the devices before selecting inputs. When correct input selection have been done, the logo of your external device will appear on screen.
May 26, 2012 | Samsung TCD1382 13" TV
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
I have the remote for my sanyo mts tv but i cant find out how to get it to switch to video mode so i can play games on it there is no button
There is button on your remote labeled TV/AV . Press the button to get a blank screen with AV written on the screen. If your game device is connected at the back to this AV socket ( Yellow / Red / White ) you will see the game menu display.
On some of the TV remotes it might not be written TV/AV but INPUT SOURCE or just a picture of a TV screen with an arrow pointing inwards ( that LOGO is the universal symbol for INPUT )
Apr 22, 2011 | Sanyo DS31590 31" TV
I have my cable plugged into a reciever and my reciever is plugged into the tv but my tv is stuck on a blue screen that says Video and when I press menu, the only options it lets me access is picture and...
Try pressing the channel down button, alternatively your unit may be on auto-sense and since it doesn't detect any other available inputs it wont change. Try disconnecting the receiver, powering down the TV and connecting the cable directly. Alternatively make sure the receiver unit, which model is it BT?, is setup to output on the AV jacks. What all types of outputs does the receiver have at the rear?
Mar 30, 2011 | Sanyo Televison & Video
How do I change the input selction without the remote?
many TV support AV after the last channel pls try last channel and go ahead you will find AV-1 THEN av-2 then channel 0 like that but i am not sure pls try
Aug 26, 2010 | Sanyo DS27910 27" TV
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Tv magnovox tv
firstly try that tv to a different tv
if this works
then check your tv av connections in side tv
also check cables continuity
if this fails buy a AV/ RF converter, have your AV be connected to a converter, and let your output be RF feed to a tv, RF input, so instead of using AV on your tv you will be using RFchannel mode
Mar 16, 2009 | Philips Magnavox 27MS343S 27" TV
Havin problem utilizing multiple inputs into Sanyo TV (avg-3259g)
if your tv has no AV IN AND OUT connections, purchase a converter from eletronic shops just around your area.
this will make you convert AV into RF signal and feed that to your tv. you have to go on a channel and search for right frequency the will search for you.
Dec 31, 2008 | Sanyo DS13204 TV
No remote-
Have you bought a universal remote for the tv? That is what we had to do to get to av mode and when you do make sure you try the input button before settling with the first code that works. We stopped at the first code that changed the channels and still could not get into av mode. Finally I tried the rest of the codes and found the correct one. HOPE THIS HELPS
Aug 10, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
70 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
