Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
Fan not working but lights are working
I've had several electricians look at the problem we are having with our fan. The fan intermittently works and all of a sudden it will stop working. The lights work fine but we can seem to find out what is causing the fan not to work.
  • 1,554 Answers
It is likely that the motor connection is faulty.
it may even be inside the motor windings.
if not in warranty.
Then you can open it and follow the ac to the motor.
Past that and you will have to replace it.
Posted on Jan 26, 2008
Outlet and ceiling fan stopped working
If it's not the breaker then I would call an electrician.
Jul 14, 2013 | Dryers
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
My car is overheating.and fan wont kick in.backfiring underhood
OK, if the fan won't work one may have to have the fans replaced,the relays, and the relay contacts depending on the severity of the problem.
I just spent $724 on repairs to my 1997 Cadillac Deville where the technician replaced the fan motors, the relays, and replaced the relay contacts at the harness due to burnt contacts there.
I was experiencing a passenger side (larger) fan that was working intermittently.
The technician discovered that the fans would work intermittently when the fan relays (3 of them) were shook.
I guess the heat got to them over the years.
Good luck on this repair.
Aug 21, 2010 | 1998 Cadillac DeVille
Could be a loose wire up inside the fan. I would be very careful in its use. Might I suggest getting an electrician in to resolve this issue. You do not want to battle a fire over a fan light issue.
Aug 28, 2009 | Hunter Ceiling Fan Light Remote Control
Hampton Bay 52" Classic Collection Almeida 52101916
Electricians can be so much fun can't they ? LOL I would ask the electrician to bypass the remote to check the fan operation first. You need to know if your problem is the remote or the fan itself.. A simple wiring change in the junction box can be done to determine which issue to focus on.. Hope this helps..
Aug 04, 2008 | Hampton Bay 52 In. White Redington...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
262 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
