I have a Ministry of Sound MOSDV014 and have tried to connect all the speakers with the wires attached however some are working and some are not - can you advise what I need to do to make them all work?
  • 8 Answers
SOURCE: No Sound on the phone
It is probably cause by some dirt in the o2 port that causing the switch that detect the headphone to stuck. try cleaning/picking them up using a small toothpick or needle.
Posted on Feb 04, 2008
spqr163
  • 37 Answers
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Posted on Mar 13, 2009
SOURCE: I have lost he instructions for my Ministry of Sound hi-fi with docking sysytem and don't know how to tune the dab radio...can anyone help?
plug it and with power on but don't turn the station on, leave it in standby mode. then press and hold mem/set on your remote. then set the hour and press mem/set to move onto the minutes. when done press mem/set again and your time is sorted.
Posted on Aug 30, 2009
SOURCE: No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
Posted on Sep 03, 2009
SOURCE: user manual for the Ministry Of Sound MOSDV110
i need a manual for ministry of sound mosaso79x ipod speaker system can any one help i cant get the ipod to play
thanks in advance
Neil
merry xmas
Posted on Dec 26, 2009
How do I wire external amplifier
In order for this to work correctly you need:
  1. Power wire (with fuse) from battery to amp (+)
  2. Ground wire from amp to car chassis. (-)
  3. remote-on lead from a 12V power source that turns on and off with the ignition if the head unit does not supply a wire. (switch)
  4. RCA connection from head unit to the amp. (sound in)
  5. Speaker wire connection from amp to speakers. (sound out)
It is easiest to start with deciding on the amp mounting location, and then running all the wires. Add an extra foot or so to each wire. You may discover in the process that you have to move things around due to unforeseen obstacles. This extra foot will help in that case. Always attach the ground wire to the chassis first and then to the amp first. Once you have the fused power wire from the battery installed; remove the fuse before trying to attach it to the amp. ONLY re-install the fuse once all connections to the amp are made, secure, have been checked twice and you're ready to test it.. This includes speakers. DO NOT for ANY reason have the amp powered up before attaching ALL speaker connections.
Feb 23, 2015 | Panasonic CQ-C1100U CD Player
Speakers connections checked contead ok but no sound
might be the wires attach to the speaker inside the case must be broken. I'll suggest you that with extra carefulness open the case and check whether the wires are attached properly or not. If not attached them if yes then put back the case and report the store from where you bought it.
Jan 18, 2012 | Altec Lansing Audio Players & Recorders
User manual for the Ministry Of Sound MOSDV110 speaker system
thanks in advance
Neil
merry xmas
Nov 24, 2009 | Audio Players & Recorders
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
May 31, 2009 | Sony STR-D600SS Shelf System
Ministry of Sound internet radio won't connect to Netgear router
yes you can go through network set up wizard and find the wpa key.
May 02, 2009 | Ministry Of Sound MOSMP080 (20 GB) MP3...
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
Ministry of sound
You need to ensure that your memory wire is hooked up to a constant power source. If you have a test light, you will be able to tell by checking to see if a wire still has power when the key is in the off position or only when the key is on.
Nov 24, 2008 | Boss 510CA CD Player
Left speaker not working...
hi, there's a big possibility that the issue you encountered in your speaker might be caused by a faulty or shorted wire. You can check it by inspecting for any sign of damage on the wire and try connecting your left speaker to a different input source.
Tirzo
Jun 14, 2008 | Harman Kardon HK19.5 Computer Speakers
No sound
It could be that the wires in the harness that go to speaker from stereo are not connecting to the leads on the stereo. If this is the case the wires to speakers are not connecting, but the wires from the power source are still good. Try taking the harness out of the back of the stereo that connects all the wires to the leads. Hopefully your wiring is labeled from the factory. If it is it might say "Left front speaker". Isolate this wire and wiggle it inside the harness back and forth. If it moves even a 1/16 of an inch it may be that the leads are not connecting. You can try jerryrigging it by shoving something in their in hopes that it will hold it in place. You may need to replace the harness.
Nov 07, 2007 | Jensen MP5720 CD Player
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
