Cell Phones Logo
T
Thomas Casey Posted on Oct 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to Watch Security Cameras on the Internet (Port Forward IP Cameras)?
Brett Duxbury
Level 3:
  • Cell Phones Master 4,352 Answers
  • Posted on Oct 19, 2016
Brett Duxbury
Cell Phones Master
Level 3:
Answers
4352
Questions
0
Helped
1120219
Points
13423
What sort of router is being used ?
are the cameras on static ip addresses ?
google search for
model of router and port forwarding
http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router
I bought Lorex Dvr with 4 wireless camera they work perfet on my i phone when i home as soon away it give massage authorize limited i have an other dvr ow swann it work perfect on my cell phone why?
needs to port forward in router at home.
this means outside global world >>> Your router Global IP ADDRESS >> .....YOUR Home Router .....>> Port forward >> internal IP address Camera using on your home network
https://www.youtube.com/watch?v=SEKqtc5bnxU
2answers
Hi, I have security cameras at home I just want to know how to apply for rooter so that I can view them even if iam away.
You already have an internet connection. More than likely you have a modem with a built in 4 port router. Plug a Network cable into the back of the router and also into the Security Camera DVR. Go to the settings in the Security DVR and choose network. Log into the modem/router and set up a port forward to the ip address you found in the security DVR network section. Download the Security Camera App from your telephone hardware provider. Load your remote ip addess (found by searching from your computer attached to your network at home using whatismyip4.host) port, user name and password into the app and you should be online to your cameras on your phone.
How to portforward port 80
You must login to the router with a web browser and try to find the port forwarding options in the menu. You must then know the ip address of the machine you want to forward it to and create a "rule" to forward all traffic from port 80 to the ip address. But beware that port 80 is used by internet browsing and you could have problems due to that.
I can not play xbox because security is to high how do i chance it
you need to give your xbox a static ip address.
on your linksys router go to internet explorer. browse to http://192.168.1.1
default login is blank password is admin
go to Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074. Go ahead and enter the settings shown above into the Port Range Forward menu.
port forward the following ports up above to the ip address that you set your xbox 360 to.
2answers
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
3helpful
How to watch IP Camera on internet by using DSL-2640T??
let me give you few suggestions and then you can take it from there.
firstly IP camera is just what its name says..it needs a fixed IP address it may be local as in your lan where it is working or a IP address from ISP.
Now when you connect it behind router... it is essentially a camera connected to LAN.
now the problem is DYNDNS.com will give access to your router since that is connected to dynamic IP addressing. However Ip camera is behind router and to access it you need to open proper protocol and port in router .consult your router manual for doing that.
with your current setup that is the only solution. however you can connect Ip camera directly to ISP line and then use dyndns as in case of router. though i dont know how feasible that will be for you.you have not mentioned IP camera model so cant help with specific details.
Network routing problem with Axis Camera's
They would need to be on different TCP or UDP port numbers ... in order to access them from the Internet. I'm guestimating that on the LAN you can access all of them because they are on different RFC1918 IP Addresses (e.g. 192.168.1.10, 20, 30) but same port number (e.g. port 80 for web.)
Once you hop through NAT to get to the Internet you now only have one IP Address. The real Internet IP Address. So now you have to have different port numbers for 2 or more cameras. For example use:
#1 port 80
#2 port 8080
#3 port 8081
#4 port 8082
How about that?
And you will have to forward each of those ports to the correct ip address for the correct camera.
Where's my free restaurant dinner? :-)
3answers
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Security
forward the port no 1024 ..in the router and when accessing the camera, try http:0.0.0.0:1024/
instead of 0.0.0.0, enter your ipaddress
1helpful
2answers
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
