Sony CPD G420  19" CRT Monitor
Problem for Sony CPD G420 (White) 19" CRT Monitor
Hi, I hope you can help. I have a Sony Trinitron
By massimo_salv on Jul 19, 2009
Hi, I hope you can help. I have a Sony Trinitron monitor. It suddenly went a bit out of focus. I am trying to find a restore function, with no success. I wonder if you have any suggestions.
Solution #1
posted on Jul 19, 2009
Not Rated)
onlyforyou
Rank: Guide
Rating: 87%, 4 votes
Follow these instructions carefully.
Make sure the monitor is in a place where you have easy access,
1. Unplug the monitor and disconnect it from CPU
2. Remove screws from the back, then remove the back, locate the flyback transformer on the circuit board, (big black thing with red wire connected to the screen). You should see three knobs on the side check to see which one is marked focus, (usually the middle)
3. Have someone stand in front of the monitor or make sure it is facing a mirror and the mirror is close to it.
4. Reconnect the monitor to the CPU, plug it in and turn them on, leave running for about ten minutes
5. Then using a screwdriver that fits, slowly turn the knob while confirming with the person standing in front of it whether it’s getting better or not. If its not try the other direction. If there is no one then check the reflection in the mirror. Once you are satisfied turn the monitor off for a minute then turn it back on, if it is ok then turn it off, unplug and disconnect it from CPU. Replace the back and screws.
Dont touch anything else with screwdriver while turning knobs. It is always best to wear shoes with rubber soles when working around electricity.
Was this helpful?
Yes
No
Solution #2
Not Rated)
dilum_wonder
Rank: Wiz
Rating: 80%, 58 votes
you have to open your monitor back. find a big part called flyback. there is two nossel in it. adjust forcus nobe litte bit for clear picture. this will definetly slove your problem.
Was this helpful?
Yes
No
Popular Solutions for Sony CPD G420 19" CRT Monitor
Questions and Unsolved Problems for Sony CPD G420 19" CRT Monitor
Do you recommend Sony CPD G420 (White) 19" CRT Monitor?
Answer
Answer
I have a Sony G420 CRT monitor which is starting to get too bright. There is a fix for this but in... (More)
Answer
i have a 19" Element tv and when i turn it on it turns on and displays element on the screen... (More)
Answer
When I start my PC the screen colour goes movee instead of black, can you suggest the remedy please?
Answer
The picture on the screen is too wide. it has choped the RH side off.How do I reduce the width and... (More)
Answer
no it is not my failing eyesight - haha! i have just noticed in the last while that the text on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
