SOURCE: Mintek DVD-2580 DVD parental control
I might have what you want. It is 88888 as set by the manufacturer. If you ever need the code for the remote control it should be 0717. I hope this helps.
SOURCE: How do you reset the parental control code?
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
SOURCE: Zenith dvb410 parental control
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
SOURCE: mintek dvd need password for parental control, to
I have a Mintek MDP-1880 player, and the manual says that its default password is '88888' Try that and see if it works. Hope that helps you.
