Question about HP Pavilion dv9000z Notebook
The volume button has a faint bluish pink light, vol not workin
The volume button has a faint bluish pink light, the volume scroll bar not working and the light is not glowing as well
  • 201 Answers
There is ribbon cable that may be loose or replaced
Posted on Jul 19, 2009
Need to learn how to use a i-pod classic
Scrolling: move your finger clockwise to scroll up, and counterclockwise to scroll down.
Select/OK: center button
Menu: goes back to previous page. hold menu to go to main menu. you may chose what items you want in this menu under settings > main menu.
Music playback screen:
to fast forward, hold '<< or >>' OR press center button once, and use the dial. clockwise to go forwards, counter to go back. when done, wait, and the diamond will dissapear.
song ratings: Hit center twice then use the dial to enter amount of stars. is saved to iTunes next sync
Shuffle: three center clicks. can shuffle by album, or song. if it is off, it plays the playlist in order.
lyrics (If applicable): four clicks in is where you can view lyrics. if you do not have lyrics for a song input from itunes, four clicks will bring you back to the main song bar.
volume: simply rotate finger clockwise (+ vol) or counterclockwise (- vol). no Center button needed. must be in music screen. (aka, now playing.)
Hold switch: while active (orange showing) buttons and scroll wheel are deactivated to prevent accidental key clicks and volume changes.
For reference and more information:
http://manuals.info.apple.com/MANUALS/0/MA630/en_US/iPod_classic_120GB_en.pdf
these are some very basics I have written, I can definitely answer any specific how-to-iPodclassic questions.
-DF5
Oct 13, 2014 | Apple Griffin iClear Crystal-Clear...
In my wildfire s set sd & phone storage the mount sd card option is not working.in this menu total space is unavailable and available space is unavailable while the sd card is workin properly in other...
Delete all messages and call logs.......if still problem persists then probably there are some malware occupying your memory which creap in if u use internet on ur phone......solution is - factory restore ur phone after backing up only important data.....if this does not work then hard reset ur phone.....press vol. up, camera and power button together for a few seconds.......download/boot mode will appear......press menu or vol. down button and scroll down to CFT calliberation ...select using menu button......phone will restart....this should solve ur peoblem..
May 03, 2014 | HTC Wildfire Cell Phone
Samsung HL-T6187S SOUND DROPPING TO 0? By itself
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Feb 21, 2012 | Samsung HL-T6187S Television
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
I have the sony str de485. When i turn it on the display doesnt turn on only some buttons light up so there is power. There is no sound coming from speakers only very faintly through sub woofer. Whats goin...
some important steps 1)check speakers & components connected correctly 2)check that MASTER VOLUME control is not set to VOL MIN 3)check muting 4)may be protective device may be activated to prevent short circuit
Feb 21, 2010 | Audio Players & Recorders
Hp laptop, dv6000 series..volume button gone pink!
Usually when the volume button is pink(orangey) it means that the volume has been muted. Make sure both on the quick play bar right of the power button and in the task bar, that the volume has not been set to mute. Also check the audio drivers and make sure the drivers haven't been corrupt and reinstall or re-download new updated drivers in needed.
Aug 27, 2009 | HP Pavilion dv6000z Notebook
I have a philips Matchline tv (29pt6361/79r) the tv works fine except it automatically turns the volume down without any buttons on the remote or tv being pushed
well depends on how far it turns the volume down as to what the cause is and if the volume bar on screen display comes on when the vol. goes down. if it just goes down a little you probably have the "smart sound" setting turned on in the audio menu turn it off and see if prob. goes away. if the vol. bar comes on the screen whenever the vol. goes down the you most likely have a bad button on your front panel and it doesn't have to be the vol. down button. it you think it is the button it would need solder work to be changed most likely shop job.
Mar 08, 2008 | Televison & Video
Volume button is stuck
something sticky got spilled on it put a little drop of water on it and whiper it off real quick that should help
Apr 20, 2007 | SanDisk Sansa m240 MP3 Player
HP Pavilion dv9000z Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
