Question about Lexicon Omega Desktop Recording Studio Sound Card
Icant record more than one track at a time.
I have connected the omega to the computer and I can record 1 track at a time but I cant record more than one track.When I select the audio input I only get the choice of stereo or mono input not the 1,2,3,4 in which I should get according to the instructions.
Welcome to my nightmare. I have been having nothing but grief with this box. Try going into your control panel and click the hardware tab. Under device manager, look in the sound, video and game controller and see if your Lexicon Input 1-2 an 3-4 are enabled. If not right click and enable them.
Posted on Sep 16, 2009
Why cant i connect to my pc anymore
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
Sep 22, 2015 | Korg D888 8 Track Recorder
My cubase LE4 software says the ASIO driver Omega ASIO cant be started? i follow the directions and try to record but the track remains blank
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 15, 2011 | Lexicon Omega Desktop Recording Studio...
How do you record on tracks 3-8? i can record only on tracks 1 and 2, this is marketed as an 8-track recorder but is it really?? if i cant record on track 3 or track 4 then i just waisted alot of money i...
Yes you can record on the other 6 tracks, but you need to assign them.
If you are having problems assigning them, don't forget that you need to clear the previous assignments (for track 1 and 2 for example) FIRST, before you try and assign to say tracks 3 & 4.
To clear assignments hold down the assign key and the previously assigned tracks should flash. While still holding the assing key, press each one of the flashing channels seperately to un-assign them. Now release the assign key.
Jan 08, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Can't get signal on an audo track.
in my system sound not working
my system is VIA samuel 2
Dec 15, 2008 | Lexicon Omega Desktop Recording Studio...
As soon as I plug in/switch on my midi keyboard, the USB LED flashes
dear sir,
your problem is very simple. please check the didi key board seriel pin.some time the seriel pin is broken. your goole problem is network problem.please check the network connectivity. otherwise operating system problem.sometimes while your installing the operating system some files missing. so first check your computer network and serial port.
thanks & records
sakthivel
Aug 09, 2008 | Lexicon Omega Desktop Recording Studio...
Trouble getting started
find the lexicon usb driver in device manager. uninstall it and reboot and let plug and play install a generic usb driver from windows.
I think this might help.
goodluck
44hink
Jan 19, 2008 | Lexicon Omega Desktop Recording Studio...
Installing omega lexicon desktop recording studio
Yes it's extremly tempramental, just keep repeating the proces it' will work eventually!
Feb 17, 2007 | Lexicon Omega Desktop Computer Recording...
Open Questions:
See all Lexicon Omega Desktop Recording Studio Sound Card Questions
Lexicon Omega Desktop Recording Studio Sound Card Logo
117 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
