Question about Western Digital (WD3200JS) 320 GB Hard Drive
Randomly stops spinning and locks up , brand new drive, installed as per instructions. worked fine for a day, now randomly stops spinning and locks up computer during use. have scanned it, defragged it all shows normal. changed bays its in, changed power and sata plugs out. even checked all programs on comp for corruption of files, it all shows normal.
    President:
  • 1,179 Answers
If all software tests check normal but the hdd locks up then you may have gotten a bad hdd. Contact the warranty department of the hdd manufacturer to arrange an RMA and replacement. They should provide you a new drive free and will give you instructions on what to do with the bad drive. Hope this helps.
Posted on Jul 19, 2009
HP DV8200 CTO Series Notebook
Greetings,
It seems that the computer itself is killing the hard drive. You got at one point the system working for two days.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Microsoft Windows XP Home Edition
Lock
have u gotten new power sorce yet and did it stop error from bad power supply not getting right voltage
Jan 30, 2008 | Visioneer 9020 Flatbed Scanner
Washer is acting erratic. spin cycle works sometimes. stops half way through cycle sometimes. got a new belt. what's next? pump or timer. both are spendy $ thanks. frigidaire FTR630ASO
The control monitors the door lock prior to and during the spin cycle as a safety feature. The washer will not advance to the spin cycle when the door lock is not activated and stops when the lock is deactivated during the spin cycle.
In your case, the door lock is working intermittently causing the washer to spin intermittently. This is probably due to a faulty door lock and switch assembly or poor connection at the control board or at the assembly itself. Replace the door lock and switch assembly if necessary.
Apr 06, 2010 | Washing Machines
I have a 2001 Mercedes C240. When the engine is running with car stopped you can feel a bit of trembling. It also cuts off during driving and at slow speeds only. Like when I will the foot off the pedal...
The first thing you do is have the engine control module scanned for fault codes. I also suggest you buy a can of spray throttle valve cleaner and clean the throttle valve and the idle speed control valve.
Apr 21, 2017 | 2001 Mercedes-Benz C-Class
I recently had an HDD stop spinning and lock up on me. I saved what data I could and purchased a new one. Within hours of installing it the same issue arose; I figured it was bad luck and had it replaced....
i think its not even your motherboard, first of all clean your PC with an air blower then replace the data cables which connect your hard drive to the motherboard.
also do replace the power supply.
Sep 03, 2009 | Computers & Internet
Brand new Dell 1545, XP pro SP3
I faced the same problem with my laptop and the fault was with the power adapter. I noticed that the cursor moved randomally only when the power adapter was plugged in. I got the adapter replaced and it is working fine since then.
Aug 11, 2009 | Acer Aspire 5610-4648 Notebook
Epson Stylus SX100 installation CD is not read
There are chances that the installation CD is faulty itself. If it is the original manufacturers installation CD, and appears to be free of scratches and smudges, this is most likely not the case. I would insert a combination of at least one other software CD and one recordable CD in the CD drive of your computer CD/DVD drive to see if these discs are being scanned, read, and show data on those CDs. We want to pinpoint the problem, to make sure that the hardware failure of CD Drive is not to blame, but it could be.
A Disc can spin around in an optical drive, and have laser read issues, and still end up being faulty, and eventually need to be replaced.
If you determine that you need a new Printer installation CD/DVD, and all other data discs work fine in that optical drive, you can download printer driver software directly from the manufacturers web site.
If you provide me all the model and manufacturer details of your new printer, I can locate this direct download link for you, and provide that to you.
Best of Luck!
Xpertdragon.
Mar 22, 2009 | Epson Office Equipment & Supplies
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Western Digital (WD3200JS) 320 GB Hard Drive Logo
240 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
