Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Unable to install the printer!
I am doing everything as it tells me but it has this constant error that it cannot copy certain DL files from the istall CD????
  • letoit Jul 21, 2009
    I am using XP. The download from the site has the same problem. I am completely lost!!
    President:
  • 1,179 Answers
What operating system are you using? The cd may not have the driver/files you need for the o/s you are running. They should have the latest drivers/install files available for download at the manufacturers website under the support area. Hope this helps.
Posted on Jul 19, 2009
I am unable to print pdf documents on my Image Class d880 printer. I used to be able to...but am not able to anymore. Any reason why this is happening?
Maybe your pdf is protected by print password, in this case, you have to use the pdf password remover to remove the print permission.Here is tutorial on how to remove it on windows:
http://www.pdfpasswordremover-mac.com/pdf-password-remover.html
Jul 12, 2010 | Canon imageCLASS D880 All-In-One Laser...
I keep getting an error when I try to load HP Deskjet 1432 Printer. It tells me it needs a certain file to load ICM.RBG... (might not be the exact name of the file needed....but it does start with ICM.
Awhile back I had the same exact problem.
First search the the installation cd for that file it wants.
Copy it to your hard drive. Suggest a directory that is simple and easy to find. Like C:\HP Drivers
Now when it asks for that file, point it at C:\HP Drivers or whatever you have choosen. Be prepared to look for more files, this is usually the result of a flaky installation program or CD.
You could also try downloading the latest installation file with updated drivers. This will often fix the problem. Be SURE to turn off any virus detection or spyware program. This is ONLY while installing the software. Virus detector's and Spyware applications can and will muck up an installation of software. Be sure to turn these back on AFTER you install drivers or applications.
Hope this Helps!
Nov 23, 2009 | HP Officejet 4355 All-In-One InkJet...
At startup iget a error message saying The procedure entry point_ismbcspace could not be located in the dynamic link library MSVCR71.dll
Can you tell me what program your trying to start that gives this error message? Also do you have XP, VISTA or Other?
Try re-installing the problem software.
Try registering the file with start -> run -> type "regsvr32 msvcr71.dll" without quotes, and press OK or enter.
If the problem still remains try downloading this file, the readme file inside has the instructions on what to do with it, then you may want to repeat the start -> run command.
http://www.dll-files.com/dllindex/pop.php?msvcr71
If the problem still remains let me know and answer the questions I've posted for you.
Thanks,
Ekse
Aug 14, 2009 | Office Equipment & Supplies
Unable to print from pc, It is givinging me an error saying Output file name, print to file. Then it just does not want to print. I have tried different usb ports aswell as making sure that it is the...
Is print to file checked in print options?  Is the printer you installed selected as default printer in Start > Control Panel > Printers / Faxes.
If all else fails, uninstall everything and start from scrath....
Jul 14, 2009 | Canon Office Equipment & Supplies
Fonts not installed
Fonts are typically available either for free or for a fee.
Only fonts that are visible in your C:\WINDOWS\Fonts Directory will be available to print.
You can google fonts and find more if you are looking.
Also, depending on the program you are using, you can save as a .pdf to print and this will "pack " you fonts into the document. You cna also use the "prepare for commercial printing" option in MS Publisher to store the fonts in the file.
Bottom line, if the font isnt installed, you cant use it.
You may be getting this error if the document came from someone who has the font but you dont. If that's the case, tell your friend you need the fonts. Just copy them out of the E:\WINDOWS\Fonts directory to your disc.
That should do it.
Jan 13, 2009 | Canon ImageClass MF5770 Laser Copier...
Please help me
uninstall your printer then reinstall it and read carefully the installation instructions showing to you.
If you doing right computer will tell you that the installation successfully complete. Then, Check all connections.
Hope it will help u.
Jul 13, 2008 | HP LaserJet 1018 Printer
Hp Pavilion a1220n -- Copy file errors when Installing windows
Maybe I can help;
When I install a new hard drive I like to re-install the operating system (OS) as well. Unfortunatly this wipes out all your files.
Typically when files do not copy it's either because they're in use or the media (your new hard drive) is not formatted properly.
Note, formatting erases everything on the drive being formatted.
Instruction for this are easy to find online but are all done for you if you use the OS install CD which will walk you through the setup, formatting, and partitioning.
If you have a way to save your files to another drive such as a usb thumb drive, external hard drive, cd or dvd, I would go about it that way. There's usually alot of uneeded files created by the operating system after a period of time and there's no sense in keeping them. They only slow your system down.
One other thing you can consider if you don't have an external hard drive is purchasing a hard drive enclosure for your old hard drive. You can find them at Best Buy. I paid about $30. Its just a case and usb cord you can use as an external hard drive and also copy any files you can still access on this old drive over to your new one.
Let me know if this helps you
Apr 20, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
Found New Hardware error message
that can come from having two of them on the printer profile..open that to check if the computer is looking for two printers.
Mar 10, 2008 | HP PSC 1210 All-In-One InkJet Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
