Vacuums Logo
Cindy Meister Posted on Oct 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased an evening bag in January 2016 and have only used it 3 times. The last time I used it, the little ball that holds it closed fell off. Can that be repaired?
Marvin
Level 3:
Top Expert:
  • Vacuums Master 85,242 Answers
  • Posted on Oct 18, 2016
Marvin
Vacuums Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053946
Points
266281
Try a shoe repair shop for this repair.
My Miele s8 cat and dog vacuum dust compartment keeps filling up with dust and cat hair
I see this all the time. The red or blue bag holder has either started to bow or it's legs aren't seated on the top of the little depressions. Check that and when you fit new bag remove the hose and check the little door on the bag is open and not closed if it's closed all the rubbish will fill the bag container rather than the bag. If this if the case buy new bag holder common problem.
tip
Vacuum cleaners: Loss of Suction
A common complaint about vacuum cleaners, regardless of the brand, is loss of suction. The motor runs fine, there seems to be plenty of power, and even some suction, but the vacuum just won't pick up even the lightest of items. There are some very simple checks and fixes to this problem most of the time.
The primary causes are: clogged hose, full bag, leaky hose.
Clogged hose: this is probably the most common cause, and will result in a damaged motor if not cleared.
Check: Remove hose from vacuum and wands. Holding one end, drop a marble or small ball into the opening and allow to roll through. If it doesn't come through the end, then the hose is clogged.
Solution: If you have a canister vacuum with an exhaust port, try connecting the hose to this and turning machine on. If the clog isn't too bad, this may clear it. If not, more extreme measures may be needed.
Never attempt to clear a clog with a coat hanger or similar length of wire, as this could easily puncture the house. Do not use water or high air pressure gun to clear hose.
Full bag: Check bag. Change if necessary. If it seems the bag should hold a little more, well, it's not worth replacing a motor, or the vacuum, trying to find out. Bag pores are easily clogged if the machine is used for cleaning construction areas where sheet rock dust is abundant. Ensure you’re using genuine bags for your machine.
Leaky hose: Over time, hoses suffer from normal wear and tear, and often abuse, resulting in cracks and holes, often too small to notice. Hoses need to be replaced at this time, and this generally results in a dramatic increase in "suction". There simply is no fix for a leaky hose.
Solution: Always store the hose properly to avoid kinking, crimping, smashing, etc. Avoid stepping on the hose, or leaving in an area where it may get stepped on , driven over, or smashed. Avoid pulling the vacuum by the hose, or otherwise stretching/stressing the hose.
on Aug 22, 2010 • Vacuums
tip
I had the same problems because I have a 80lb indoor Australian Cattle Dog /...
I have written a guide to help with the cloth bag odor problem. View it simply by clicking this link....YOU'LL BE AMAZED AT HOW EASY IT IS!!
http://reviews.ebay.com/DEODORIZING-CLEANING-THE-KIRBY-VACUUM-OUTER-CLOTH-BAG_W0QQugidZ10000000003719865
HAPPY VACUUMING!! :0)
Marci
Our kirby generation 3 trips out when the rubber protection sides touch a wall or object
A hot wire is hitting the frame. Unplug it take your time and remove the housing around the motor and you will find the stripped wire. Cover it with GOOD electrical tape and you should be all set
Dyson Canister Clip Replacement
You can purchase a replacement clear bin assembly for your DC25 directly from our online store - visit www.dyson.com and click 'Spares' (UK), or 'Parts' (US).
However, I'd encourage you to give our free customer Helpline a call, as we'll be able to confirm if this replacement is covered under the terms of our 5-year guarantee. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
2answers
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 • Vacuums
10helpful
5answers
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
2answers
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Cover won't close
Try removing the bag and closing the cover. Unless that piece that holds the bag has gotten loose, there isn't anything that should prevent that cover from shutting, so it may just be the way the bag is sitting.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
