SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
