1995 Toyota Camry Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
95 Toyota Camery, The car remote locks and unlocks, the security led flashes when set, the locking and unlocking beeps and alarm sounds are now gone. Whole system replace or is it the loud speaker unit under the hood?
Anonymous
Level 2:
  • Expert 88 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Answers
88
Questions
0
Helped
93536
Points
275
If the light is flashing and the central locking works then its all good the speaker wire has maybe broken inside plastic casing but hey if it all works with out the noise then leave it
  • Anonymous Aug 07, 2009
    if the light is flashing and the central locking works then its all good the speaker wire has maybe broken inside plastic casing but hey if it all works with out the noise then leave it
I assume the factory alarm was somehow bypassed when they installed the remote start is there a way I can make the factory alarm work when the doors are opened without key,?
To arm content theft alarm.
1. Open the door.
2. Lock the door with the power door lock switch or
the remote keyless entry transmitter. The
SECURITY light should flash.
3. Close all doors. The SECURITY light should go off
after approximately 30 seconds. The alarm is not
armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
Security Lock Flashing. Even when I lock with key it stops flashing but stays on. What is solution?
You are going to have to use the Key fob or remote alarm fob to go threw a set of lock and unlock procedure. Crank the car shut it off remove the key outside the vehicle at a distance of at least 30ft then lock the car, wait till it arms and the dash light blinks once this is active you want to unlock the car with the remote. If this one does not work do the same thing except when you unlock it do so with the key to re open after arming security.Also make sure you have both fobs or all remote fobs with you when you do this lock with one unlock with the other then vise, versa ok if you need any further help just ask also make sure your battery is fully charged and the terminals are clean this will affect a security system bad a low battery or low battery in the FOB's.
1helpful
2answers
How to disable alarm on 95 jaguar xj6
Your Car is equipped with an Electronic Security System. If you disable it (which most probably you can not), you will bet on security of your car. If you still want to disable it, you should contact your Dealer or Authorized Service Station with Purchase Bill. If possible, they'll change locking system to old one.
1helpful
Hello, so I'm 20 years old and have recently bought a 2004 Toyota Camry LE from my grandmother because she recently just bought a new car. Car works great, has less than 50K miles on it, never were any...
sounds like the alarm sensors are quite sensitive and r picking up air vibrations or could b a cat climbing on the car u should be able 2 get the alarm ajusted
1helpful
My battery was dead in my 1999 camery this morning. I took the battery out and took it to the auto parts store to get it tested. They told me I needed a new battery so I bought it and brought it home and...
If you have a keyless remote, use it to lock and unlock your doors-if not, lock your door with the door lock, close the door, and unlock the door with the key. This should reset the alarm.
5helpful
I have a 98 Nissan altima gxe and my alarm won't honk when I lock the car but the lights go off when I lock it and Wen I take the alarm off no honk or lights go off Wat can I do
holdboth the lock and unlosk buttons on your remote simultaneously for about five seconds until the lights flash and horn chirps.that should do it.if not i believe these models used a separate horn for security system.possibly fuse for this horn is bad or the horn itself is bad.to see if this horn works lower drivers window.stand outside vehicle and lock doors with remote.wait about a minute and reach in window and MANUALLY unlock and open door(do not use power door lock button)this should cause the system to activate...horn should beep and headlamps should flash.if horn beeps try my first suggestion.if it doesnt beep and just the head lamps flash check fuses and horn for security system.
6helpful
2answers
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Replaced the battery on my 95 Camry and as soon as I open the door the alarm starts sounding. Help.
you set off the alarm.if you do not have the remote,get one as you need to unlock it with the remote.some vehicles if you lock and unlock the passenger door twice,will turn it off. call toyota,they can reset it more than likely with the obd2 computer. in the future,when changing the battery,a back up battery has to be wired in parallell with the main battery before it is disconnected.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
