200443016 Motor Armature Assembly Ridgid R3002 Compact Orbital Reciprocating Saw Parts
SOURCE: Reciprocating saw armature removal
usually there is a screw in the diaphragm to hold that assembly tight. You need to remove the brushes first and you might need to GENTLY pry the diaphragm from the motor housing. Then using a soft blow hammer tap the armature out of the plate. I would recommend replacing the bearings and brushes when doing the armature. Let me know if you need more assistance.
SOURCE: how do I take apart a Ridgid R3030 reciprocating saw
scroll down to the bottom of the page on the link, it gives you some dismantling instructions.
Ridgid R3030 One Handed Fuego Reciprocating Saw Parts
you may be able to order your parts here.
RIDGID R3030 Reciprocating Saw Parts
Testimonial: "Thanks that did help now I just have to figure out how to unsnap the front housing"
