Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak esp 3 setup .exe file will not run.
Printer works as stand-alone,ie. I can copy a document,but the
software disc won't load to the pc.The disc spins for about 30 secs.
then stops.Tried 'start-run-setup.exe' etc.,nothing happens.
Downloaded 'aio_install.exe file from 'Solution Centre', won't run.
What's odd about this file is that the file size is shown as 250mb
but when you hit download the file you get is only 1.38 mb.
I've emailed the problem in but had no reply as yet.
Can anyone help please ?
  • 1,511 Answers
If the device is installed, uninstall it.
And then re-install it, using the driver.
You can download the drivers from different locations.
Like Here
Here (Select the desired Device first)
Or you can also try the official Kodak Site Here (Yes its a 1.38 mb file, but it will download the rest of files when you'll install it)
If i was helpful, Kindly do Rate!
Posted on Jul 19, 2009
Lost cd and need to connect printer to new laptop
You can download the same by visiting the website:
http://support.en.kodak.com/app/answers/list/c/890/selected/true
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Printer Model number and the OS that you are using.
To install just Double clock on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Oct 18, 2011 | Kodak ESP 5 Printer
When i try to load software for kodak esp 5250 all in one printer i keep getting this "E:\setup\kapmaster.exe/cd/m.company name=eastman kodak company /code 1033 x=0 y=0 (code 101 707)
Try going to Kodak's website and download a more current and updated version of the software that is more compatible with your operating system. WWW.kodak.com
Sep 20, 2011 | Kodak ESP 5 Printer
Setup cannot find setup.exe. browse to a valid installation source - microsoft office enterprise 2010 corporate final?
Hi there! Welcome to FixYa!
If you are getting error message during setup of Office Professional 2007 use this stand alone installation file instead. Just download it and run to install. Also save your copy of the file to a disc for future use.
Here is the link http://tinyurl.com/y5vml4
Sep 03, 2011 | Microsoft Office Professional 2007 Full...
The disk to install my Kodak ESP 3 is broken. How can I install it without one?
You can get the latest software for your machine, direct from Kodak here.
Just enter your model and search.
Mar 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Unable to access Kodak EasyShare software
Perform a clean uninstall:
1) uninstall the software from your OS
2) run the clear utility program www.kodak.com/go/clear
3) type "regedit" w/ out the quote on the run command, then delete hkey_local_machine\software\kodak
4) run disk cleanup
remove the ff:
  • Downloaded Program Files
  • Temporary Internet Files
  • Recycle Bin
  • Temporary Files
5) reinstall the software again at www.kodak.com/go/edl
May 29, 2009 | Kodak EasyShare Z760 Digital Camera
The installation software will not start in my 8 yr old compac
Try copying it to the Pc, then run the setup.
Hope this helps
Richard.
Apr 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 7 Stops printing at 97% done
I can understand your concerns. Just try to copy a document from the printer , by placing it on the scanner glass of the printer and by pressing Copy on the printer.if it copies,that means the printer is working absolutely fine.As far as the printing from computer is concerned,i would recommend you to
Kindly go to control panel-add or remove programs and then remove bonjour,Kodak all in one printer software and microsoft.net framework Go to start,go to run and type in "services.msc", without the quotes in the open box and press ok. restart the following services by clicking on stop the service and start the service. 1. background intelligent transfer. 2.cryptographic service. 3.windows installer. 4. remote procedure call locator. 5. printer spooler. make surethat they are set to automatic not manual.
install the latest version of Kodak software from www.kodak.com/go/downloads Your issue will be fully resolved.
Mar 30, 2009 | Kodak ESP 5 Printer
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
406 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
