Question about Bvlgari Watches
I have a Bvlgari Diagono rubber strap watch. The strap is held on by a pin that looks like a screw.One end of the pin fell out and is lost and i am in need of buying a replacement pin.Can you supply the part ?
shaggyrat
  • 1224 Answers
SOURCE: Resizing my watch
screw
small jeweler tools
take to jeweler for 5 bucks they will knock a link or 2 out for you
Posted on Jun 12, 2008
escapement
  • 2334 Answers
SOURCE: I would like to adjust
To do that you need a hardened steel pin and small hammer. Use that pin as a chisel and drive the bracelet pins out. Split pin end must come out first. When driving pins back in- blunt end goes in first and split end last.
You can make driving pin from hardened needle by blunting the pointed end.
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com
/products/H45820.jsp
- Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: AR 1029 armani watch replacement strap
All the info you should be able to find here:
www.emporioarmaniwatches.com
You can email, get customer support, call by phone or place an order.
If you can't find it there, try to buy it on ebay. Alternatively you can visit online shops by typing the name and model of your watch into your browser.
Posted on Jan 19, 2009
  • 11 Answers
SOURCE: finding replacement watch band
Hmmmm to get an orange rubber band you will more than likely have to go thru Bvlgari. I have access to a lot of watch band but I have not seen an orange rubber band in any of the catalogs I get. You can contact them at 1-800- BVLGARI
Posted on Jul 31, 2009
Invicta watch instructions
Straps are usually held in place by two spring loaded metal pins between the two lugs on either side of the strap. Look at the ends near the lugs you should be able to see them, use a very small flate blade srewdriver to pull back on the pin and once you get it, it will pop out of the hole its in.
Aug 18, 2014 | Invicta 15997 Mens Venom Chronograph Blue...
Cracked spindles the movement watches, watches do not work. I have a repairman, I need new spindles. Thank
Not all watches/jewelery stores around the world sell Bvlgari luxury goods, therefore
you should visit http://us.bulgari.com/customer_service
to get services or to order parts for your repariman.
Visit Store Locator page to find the address and phone number of the boutique nearest you. You may also purchase a selection of Bvlgari watch products directly from Bvlgari website (currently available in the US only).
Q: How may I get my BVLGARI watch repaired?
A:
Please contact the BVLGARI boutique or authorized dealer where you purchased your BVLGARI watch.
For Japan, kindly refer exclusively to the Bvlgari boutiques in Tokyo Ginza or Osaka Umeda. Visit Store Locator page to find the address and phone number of your closest boutique.
I hope it helps.
Feb 19, 2011 | Bvlgari Aluminium Whtie Dial Black Rubber...
Where do you buy replacement watch strap for this watc
mcdevito75 here, Almost any Jewelery shop should be able to get you a new strap. Original strap most likely will have to be ordered though.
Jul 14, 2010 | Bvlgari Diagono Scuba SD38SSDAUTO-SLN...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
After I had the battery replaced the watch is being slow
If your watch is an electronic radio controlled type , then it may be set to the wrong time zone.
Try pressing the mode button to reach the time zone setting and use other buttons to change the city.
Apr 29, 2010 | Bvlgari Diagono LCV35SSD/SLN Wrist Watch
How do i maintain the color of the rubber strap ?
Replacement is likely to be the only answer. Perhapos you could try another style of strap from your local watch shop.
Jan 21, 2010 | Bvlgari Rubber Band Watch
Bvlgari BULGARI SD 38S L2161 steel chain
I have the same pb . did you get any solution yet.
by the way I have to replace the rubber strap too.
Nov 09, 2009 | Watches
How do you remove the pin out of Starck and Fossil PH1100 watch?
Ok, so if you are like me then you probably thought removing the three tiny screws from either side of the strap, and cutting segments of the strap and re-screwing the clasps back was going to do it. Unfortunately one realises that the clasps do not slacken to let the rubber straps out even after the screws are off. The critical point is to get the side pins out which is no simple feat. Getting the pins out releases the clasps and the rubber strap.
To get the pins out, use a wire cutter to cut down a paper clip to a length of 1 .5 cms or so. Hold this with a pair of tweezers along the axis of the pins while you hammer down in the direction of the small arrow inscribed on the metal clasp. With persistence a part of the pin comes out from the other end and you can then pull it out completely with a pair of pliers.
Removing the two pins with release the ends of the rubber straps. cut away segments as required while trying on so that you dont cut too many. Make sure you cut the same number of segments on each side. I had to cut three from each side since I have very thin wrists.
Now put the rubber strap back hold the clasps in position and push the pin back in place. Put the screws back and you should be in business.
It sounds complicated but is quite simple if someone shows you how....which I hope I have been able to.
Sudipto, India
Sep 09, 2009 | Watches
Watches Logo
409 people viewed this question
Top Bvlgari Watches Experts
Ansel Alberto
Ansel Alberto
Anthony Cardenas
Anthony Cardenas
rhodesworks
Are you a Bvlgari Watch Expert? Answer questions, earn points and help others
