Question about Mitsubishi VS-45609 TV
50 " mitsubishi projection tv
Convergence is messed up how do I get the board or repair parts
  • 205 Answers
Re: 50 " mitsubishi projection tv
This website:
says your model uses the STK393-110 convergence chip. Another site I looked at said that was a 6 channel amplifier so I'm guessing you only need one to repair your TV.
If you do some google searches on "stk392-110 convergence problem" you'll find some good sites that discuss how to repair the tv. The STK392-110 is a convergence amplifier that is used any many other sets.
Good luck.
Posted on Nov 19, 2007
0 characters
3 Points
My picture flips to and from a balanced convergence to one that seems to arc? Any thoughts on a repair?
Tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have a colors shadows pictures or 3D look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65819 TV
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
Oct 24, 2010 | Mitsubishi WS-55807 TV
Where can I get a module and ic for a mitsubishi ws55807 projection tv?
If you are talking about convergence, this model uses 2 of the STK-392-570 convergence IC's which are located on the middle circuit board.
The board has not been available for a long time and one seller on Ebay has the chips at about 14 dollars for a pair.
Repair requires removal of the middle board and the chips are soldered in.
I do have start to finish, step by step instructions for this repair in this model; they tell you everything you will need and how to do the repair, I can post them here for you if you want them for free.
Considering that even if the board was available it was well over 100 exchange it is much cheaper and better to do it yourself.
Let me know if you have questions or concerns.
Aug 04, 2010 | Mitsubishi WS-55807 TV
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Electrolytic caps
Regular caps
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Convergence board
Jun 01, 2008 | Mitsubishi WT-42315 42" TV
My projection tv
never herd of a stabilizer sounds like your convergence amps are bad
Oct 29, 2007 | Mitsubishi WS-55807 TV
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Convergence board
It wouldn't be the entire convergence board, you more than likely have a bad convergence STK-IC. Replacing the IC will take a good bit of knowledge and training as far as electronic repair is concerned, plus a complete convergence set up. In other words, unless your certified, you need to contact a tech. The convergence set up alone has driven men to drink.....
Aug 28, 2006 | Mitsubishi VS-45609 TV
Mitsubishi VS-45609 TV Logo
417 people viewed this question
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
