Question about LG 42PG20 42 in. Plasma HDTV
I have a plasma with a USB port, I've put the memory stick in the USB port, but the t.v is not picking up the USB. Please help
  • 12 Answers
Have you tried another or other memory sticks?
Posted on Jul 19, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I own a LG Plasma 42PQ2 tv and I want to watch movies from an external hard drive through the USB port but it does not show any movie files on the hard drive.
The USB port on the TV might not have enough power to power the external hard drive. Can you try putting a movie on a USB memory stick instead, and see if that works?
Mar 10, 2011 | LG 42PG20 42 in. Plasma HDTV
I am trying to copy a movie (previously copied onto my ps3 via memory pen) from my ps3 to my windows 7 laptop. When i hit copy a message comes up saying "connect storage media at the save...
Hi fat_cheesy_b
When you insert your usb stick into the usb port you then go to the movie you would like to copy hit triangle copy then you need to find your usb stick in the list so you can transfer the movie to there..
So firstly you want to make sure your usb is big enough to transfer the movie on there around 2gb would be find...Then you insert your usb stick into ps3 turn your system on go to the movie you want to copy from your ps3 system hit triangle copy and your usb device should flash up on the screen for you to select...
If your usb stick isn't being displayed you need to convert it to fat file system which is easy to do you put your usb stick into your computer go to my computer right click on the usb stick and select format to fat file system that way the ps3 will recognize the device..Try this if you need more help please be sure to reply back and i will be happy t help you =) cheers nikki (Please rate my answer)
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
Can i use a usb memory stick to view media on samsung ps50b451 plasma t. if so how.? Thanks
Hello. You will have to get the cable to connect your computer to your tv. Then put the memory stick into the computer and view it. J.
Apr 11, 2010 | Televison & Video
I left my memory stick in my lap top. Dislodged
i guess you just broke the usb.. try to connect on other pcs if still works...hope this helps..
Sep 01, 2009 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Need pictures off memory card
More than likely this is not a memory stick problem, but a computer problem. Have you used this port before for other uses? sometime a port will get sloppy( for lack of a better word) and you may have to tilt or hold the card with your hand, so that the computer will pick it up. Try that.
Hooe it helps.
Mar 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any...
motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Mar 30, 2008 | Acer TravelMate 2300 Notebook
Usb ports not picking up memory stick
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Jan 30, 2008 | Computers & Internet
LG 42PG20 42 in. Plasma HDTV Logo
314 people viewed this question
Computer Repairing
Computer Repairing
