Question about Alpine Car Audio & Video
I have a Alpine SWE-1000 subwoofer with no wiring diagram. Ive sorted the power, earth and speaker cables but one remains ! The cable is a single blue/white stripe, any idears ?
    Scholar:
  • 56 Answers
No i do not have a wiring diagram for this exact Speaker but this speaker is self powered yes?
This blue and white lead is your remote turn on lead, this allows the amplifier to switch on and off with the vehicle, instead of just being on all the time and drain your battery.
This wire should be spliced in to an accesory that turns on and off with the flip of the ignition switch. If you could It would be best to splice it to the radio turn on lead. On your radio, there is a lead that should be labeled remote if it is aftermarket. If it is stock then you have to use a volt meter and back probe a lead until you find one that switches on with the igrnition switch, you should get one with battery voltag(12v or more) and one a ground (.11) and one with battery voltage when on and no voltage when off(this is the one you want to splice in too.
Posted on Jul 19, 2009
8" compact subwoofer not working it was installed
post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Oct 10, 2013 | Alpine Swe-1000 8" Compact Subwoofer...
Can I mix subs
You can, but if you wire them in parallel that is a pretty heavy load on your amplifier. It may even sound better to use one sub until you can get some more power behind them.
Rule of thumb, you can never have enough power! Check out my tips on wattage.
Mar 05, 2010 | Alpine SWE-1241 Car Subwoofer
99 Mazda Protege and Parrot CK3100 Problem
Some of the autoradio has the mute function already included to the autoradio, and when you add it, it may create troubles.
Then try without the mute cable connect and see if it is working.
Did you select the harness which the right reference of audio system?
You will have to ensure it.
Jan 24, 2010 | Alpine Type-E SWE-1042 Car Subwoofer
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
I have this speaker and it dont work
You dont want to do any repair to that sub... take it to a trusted alpine dealer and see if it qualifies for warranty repair... unless you get a high end sub like orion hcca's or others of that quality you cannot repair them and should never attempt to... any repair you do to them will make them distort unless you have the proper tools and know-how to do it
Apr 06, 2009 | Alpine SWE-1043 Car Subwoofer
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Alpine CDE-9880R INTERRUPT MESSAGE ON SCREEN
Yes after speaking to a alpine tech at their support centre it was due to on of the cables on the back of the stereo which is used to detect a blue tooth device was touching a earth connection so has to insulate the cable now all working ok.
Nov 07, 2008 | Alpine Car Audio & Video
Where do i connect my amp to my paosonic cq-dfx301u
On the the back of the unit there will be be a set of rca leads marked pre out run set of rca leads from these to the input connectors on your amp,you will also need to run a single wire from the wiring harness of head unit look for a wire marked remote (usually blue)run this to the terminal on amp marked remote ,you will also need a fused power cable run to battery +and a earth cable - screw this to metal part of chassis ,then run your speaker wires make sure + - symbols on speakers get connected to + - terminals for speakers on amp.
Apr 20, 2008 | Car Audio & Video
Car Audio & Video Logo
609 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
