Question about Fisher Paykel EcoSmart GWL15
Fault code 31--bearings also sound noisy - Fisher Paykel EcoSmart GWL15
  • 35 Answers
Feplace bearing and belt....
Posted on Jul 19, 2009
Noisy water pump from my mini is this a common fault
I have answered lots of Mini questions and this is the 1st one about the water pump being noisy. The problem is caused by the pumps shaft bearing seal leaking, this destroys the shaft bearing. Don't let it go so long that the shaft breaks, and it will.
Jan 23, 2012 | 2004 Mini One
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
Hotpoint TDL 31. Seal between drum and door seems worn
Yes espares.co.uk will have parts and advice, sounds like you could have bearing problems...if its noisy on spin....
Apr 08, 2010 | Dryers
Noisy motor
Is this a motor fault or drum bearings..if its motor then sounds like bearing on armature gone, you could fit new armrature complete with bearings or new motor....Plaese leave me feedback
Apr 08, 2010 | Washing Machines
My washing machine has been sounding very noisy in the spin cycle, and today it started beeping "asking for a service" code 131. It is approximately 11 years old not sure whether to bother with a service...
if your unit has a lot of use then the noise is proberly bearings r faulty.leaking is proberly due to main seal fault. ring service centre get a qoute for main seal and bearing replacement.also an electrical fault has happened proberly due to leak,so that could b added cost.good luck with it please reply if u need more help.
Mar 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have fault codes 31 and 42,42 was explained as
31 is throttle position sensor, 42 is Idle switch
Dec 06, 2009 | 1994 Subaru Impreza
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Drum wont turn
Sounds to me like the rear bearing is seized up. Seeing how you describe its been noisy for ages I would say the porblem is the bearing. Its not a easy jub to replace for a novice.The entire tub must be removed and taken apart to replace the rear bearing. To take the case apart its only the front panel with the door that that will come off. there should be a wire with a spring that holds the bellows to the door. remove that and the rest should come apart from the inside. Dont forget to disconect the dor switch.
Aug 05, 2007 | Hotpoint WMA31 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
83 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
