Question about Acer Aspire One PC Notebook
Were is the recycle bin on the aspire one - Acer Aspire One PC Notebook
  • Chris Hingee
    Chris Hingee May 11, 2010
    Have you lost the recycle bin? Which Windows are you using. XP ot Vista?
  • 83 Answers
If you have Windows Vista installed on Aspire One PC Notebook and it does not have the recycle bin (trash can) on the desktop by default. Here’s how to get it back.
  • Right click on the desktop.
  • Choose Personalize.
  • On the left side menu, you should click Change desktop icons.
  • This will show you the desktop items that you can have appear.
Most people will want Computer, Recycle Bin, and User’s Files checked off so that they are easily accessible from the desktop.
Posted on Jul 19, 2009
    President:
  • 1,179 Answers
It should be on your desktop if you are using Windows[will look like a trashcan]. If it is not there then you can place an icon there by; 1. If you are using XP right mouseclick on an open area of your desktop and select properties. You will see the tabs to set up desktop appearance and icons. or 2. If you are using Vista, right mouseclick on an open area of your desktop and select personalize. Same type of tabs so you can choose the appearance and icon setup tabs. Hope this helps.
I deleted photos from my cyberlink youcam and I'm wondering if there's a way to access the trash bin? Or did I permanently remove them?
if you only sent them to the trash they are still there if you emptied the recycle bin say good bye.... go look in the recycle bin.
Sep 30, 2013 | Acer Aspire 5100 Notebook
How do i get my icons back on an acer laptop
You might have deleted the icons click to open the Recycle Bin once open you could see your icons click restore items
If the icons are not in the recycle bin click start all programs right click on the program you need the icon click send to desktop to create short cut
hope this helps
Nov 12, 2012 | Acer Aspire 1690 Notebook
Where is the recycle bin??? Acer 5720-4126
The "Recycle Bin" is a name given to a directory that retains the addresses of deleted files and directories.
It is normally shon as a link on the desktop.
Hope that helps.
Nov 15, 2010 | Acer Aspire One PC Notebook
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows CE device
Sep 14, 2005 | NEC MobilePro 880
Windows CE device
Sep 14, 2005 | NEC MobilePro 750
Windows CE device
Sep 14, 2005 | NEC MobilePro 250e
Acer Aspire One  PC Notebook Logo
515 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
