Question about Garden
Titan-pro does nt sell the parts for titan-pro on there site so who does sell the parts?i need a unloader vavle cap.
  • 1 more comment
  • lozalawrence Jul 19, 2009
    cant phone cause i live in uk and its a free phone in america and ive just tried to email and wont let me,
    i will try these american sites but ive tried one american site already and they say its a european one,so if you can find any european site this would be helpfull,thanks for trying.
  • lozalawrence Jul 27, 2009
    thanks
  • 3,230 Answers
Follow the below link for UK supplier -
http://www.eurocarparts.com/ecp/s/Competition
good luck..
Posted on Jul 19, 2009
  • 601 Answers
Hi..
Check this site they do sell parts for pressure cleaner.
http://www.pressure-washer-parts.com/
Thanks
Smith
Parts diagrams
We call that a duck bill vavle. You may have to buy fuel cap for it. The Home Depot should be able to help you with that. Or you can call Ryobi, I think they will sell you one direct
Sep 02, 2014 | Ryobi RCS4040CA 40cc Petrol Chainsaw...
Do the spring end caps inside the 315747GS unloader valve face the spring or the ends of the valve
This parts diagram for the pump should answer your question http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/580751651.html?p=22
Jun 08, 2014 | Craftsman 2500 PSI Briggs & Stratton...
I have a 6.0 HP craftsman PW and i rebiuld the pump with the kit for new orings and sleaves. Now when i try to start the motor it is tight. It will only run for a very short time. Is there a pressure...
No this sounds like the unloader valve . What dose is when the trigger is off it allows the presserized water to recurilate back through the punp . The theromal relif valve is just what it says tempature sensitive blows at 145 degrees and works more like the thermostat in your car. The unloaded valve is under the pressure control knob and its part of it most of them are not serivceable but it may just be stuck if you take it off spray some WD 40 in it you may be able free it up It is likely it has an adjustment on the top of it it mabey under a plastic cap that you have to pop off but the adjustment is not likely the problem but may help you in freeing to needle valve inside of it .The problom with powerwashers is every body wants to sell them but they don't build them . A half of dozen companys make the parts any there it olny 2 differant disgns for the unloaders and pumps and the cam system that makes the pump turn so if you need parts you realy have to do some home work on line and check a lot of differant ID numbers Well i hope this will help you some but try to free the needle in the unloader valve first because that is your problem
Mar 26, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Looking for plug for water go in s3501
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop handle broke, is there anyone who sells the replacement parts for these?
i know of a great site that sells all kinds of shark parts check it out
http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok
Nov 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a 08 Nissan titan and my trailer lights don't come on, blinkers,flashers, and brake lights work, but when i turn on lights-nothing. Any ideas
Yes you need the tow relays. U-Haul sells the set of three for around $25. Dealers sell them for a lot more. Do a web search for 'Titan tow relays' for more information.
Feb 28, 2010 | 2005 Nissan Titan
I have a titan pro power waser the 7hp version diesel motor.I cant get it to take a feed from the detergent i want to use! any ideas??
I have the exact same machine and had the same problem. If you've tried running the washer with a water tank as the source, you will know that it needs at least some level of pressure - i.e. the water tank needs to be higher than the washer. The detergent input supposedly work by dropping the little feed hose in detergent.... it doesn't. This needs rigging up with a fixed hose from a container higher up than the washer to create some pressure. Don't forget to put an air escape hole in the top of the container or the liquid won't drop.
I also found the battery on this model needs recharging frequently, at least once a month if used daily. Keep a check on the oil cos when the engine oil gets too low the electric starter won't start it - it acts as though the starter motor is dead, just top up the oil. Always disconnect the hoses and drain them and the machine to increase lifespan. The hoses are only hydraulic hoses meant for hydraulic fluid i.e. oil, so water degrades them over time. Errr... keep the quick release fittings lubricated or they seize up. Can't think of much else.... they work rather well for the money but could do with a properly written English manual rather than a Chinese translation with information all over the place, and none of the above mentioned.
May 09, 2009 | Garden
Need to get axles off a 2005 Nissan Titan
Two choices. Find an axle assy from a wrecked truck, or if your ring/pinion gears are OK, install Detroit Locker TrueTrac to replace spider gears. Good luck.
Mar 18, 2009 | 2005 Nissan Titan
Bissel proheat cleaning solution dumping out
Replace the soap dispenser, the new one will come with a new vavle. Part # 2101785, or just the cap and valve #2101795.
Aug 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
