SOURCE: kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: kenwood 135
sorry about the delay I was on holiday, if you haven't solved the problem yet I would suggest that you check that you are getting both power supplies (red and yellow) and if not the first thing to do is check the fuses in the car. Let me know if your'e still having problems.
SOURCE: Locked car sterio
I found this on another site that I used for my kenwood and it worked (mine was type 3):
Type 1
Type 2
Type 3
push buttom "track up" for 3 seconds
Hope this helps.
SOURCE: my kenwood car stereo deck has a code that i
you need the code to reset it, contact the manufactuter is the only way
