Question about Yamata FY14U4AD
Sewing machine stopped making the stich
All of a sudden while sewing my machine stopped making the stitch. I've rethreaded it multiple times thinking it's threaded wrong but i'm doing it how i usually do it. the stitch just doesn't stay locked together and i do know know what to do. It's for a yamata FY14u4AD overlock machine
  • kquan2 Jul 19, 2009
    i've already tried that multiple times. The loopers are threaded properly but it's still not making the chain. I feel like the loopers are catching the top needle. Any thoughts?
  • 208 Answers
Unthread the needles, rethread the loopers properly, then rethread the needles. Make sure that all four threads are pulled securely into the tensions and retry.
The loopers must always be threaded before the needles or it will not chain.
Posted on Jul 19, 2009
What causes loose, loopy-looking stiching on the underside of the fabric?
Rethread the machine. Its almost always caused by poor quality threads or misthreading.
Aug 25, 2014 | Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
My machine is baby lock.it suddenly got a problem.it is: it sews a few stiches and stops and it goes on like this
here are some suggestions, if the suggstions don't help then it
would be a good idea to have the machine check to see if something
in wrong with the computer part of the machine
1. change the needle--make sure it's the right needle for the fabric
2. rethread the machine top & bobbin,,make sure to use every
thread guide
3. make sure the bobbin is turned the right way in the bobbin case
4. clean under the needle plate & in the bobbin area for lint
Oct 12, 2012 | Baby Lock Sewing Machines
Kenmore 385 81808 sewing machine will run, but stiches do not appear on fabric.
try changing the needle--make sure it the right needle for the fabic
being sewed
also try rethreading the sewing machine top & bobbin
make sure to use every thread guide
it's also possible that the sewing machines timing needs to be
checked at a sewing machine shop
Oct 04, 2012 | Sewing Machines
I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
Apr 23, 2012 | Brother SE350 Mechanical Sewing Machine
Suddenly my brother xl-2220 is sewing strangely! The top stich is fine, no tensio issues, but when I look at the bottom stitch it isn't right! The stitch is very loose and looks like the pattern a snake...
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
Apr 21, 2011 | Brother XL-5340 Mechanical Sewing Machine
Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
May 22, 2009 | Brother Sewing Machines
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Machine is not making stiches
Probably nothing serious. I suspect it is incorrectly threaded. Check the needle is in right and rethread top and bottom according to the manual. There are some good youtube videos showing this if you do a search there.
Aug 25, 2007 | Kenmore 19233 Computerized Sewing Machine
Yamata FY14U4AD Logo
354 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
