Question about Onkyo TX-SR606 Receiver
My son left my Onkyo 606 on for 2 days in DVD mode though the DVD player was off. I found the receiver to be very very hot esp since the cabinet door was closed. I am concerned whether this heating episode has damaged any internal part. How can I check if nothing is damaged or nothing will get damaged in the near future bcos of this heating episode? Thanks
  • shuklaashish Jul 19, 2009
    Since the receiver remained switched "on" for more than 48 hrs (display said DVD mode; though the DVD player was switched off), it was very very hot as if there was an oven inside it. Will the extreme heat have damaged some internal circuitry or electronic part?. Or will i see the problem after some days?. The receiver is less than a year old.
    My Onkyo 606 receiver remained switched "on" for more than 48 hrs (display panel said 'DVD' mode; though the DVD player itself was switched off). After 2 days in this mode the receiver was very very hot as if there was an oven inside it. Will the extreme heat have damaged some internal circuitry or electronic part? Or will i see the problem after some days?. The receiver is less than a year old.
  • 258 Answers
This receiver does throw off a LOT of heat when powered on, so please be certain you give it adequate cooling space or you'll see the "OVERLOAD" feature turn everything off to prevent damage, make sure there is nothing covering the heat vents on the top so it can breath, don't worry this device is protected by this overload and overheating feature so you can be confident no damage has been done to internals ok, your welcome
Posted on Jul 19, 2009
  • 4,472 Answers
I am an onkyophile myself. There is almost no chance this caused any damage to your system. If everything is working properly then you don't have anything to worry about. Onkyo's are built very well. Normally you don't want to leave it on for that long of a time, but I have on mine several times and have had no problems. Only way to know is to use it crank up the tunes for a while. If everything is working as should then you have nothing to be concerned about. Thankfully you have an onkyo. If you need any other assistance please let me know.
Thank you for using fixya,
Lee
  • 601 Answers
Hi...
I don't think if you switch on the player for so long will create any problem apart from heating.
You should keep the receiver on open so that the heat sink count pass the heat to the surrounding air.
Thanks
Smith
I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it. http://www.highdefforum.com/high-definition-receivers-recorders-players-tivos/121956-repairing-onkyo-htr667-aka-606-a.html
and the youtube vid: http://www.youtube.com/watch?v=gj0x5S9ez5U
Good Luck!
Apr 04, 2010 | Onkyo TX-SR605 Receiver
TV not receiving video signal from DVD. Component video setup from DVD player to SR-606; DVD input assigned to IN1; TV receiving TV signal routed through same HDMI working OK. Was working OK once. Didn't...
This model has a defective hdmi pcb assy. this is a well know defect with this model.If under warrenty have hdmi bd replaced if not the hdmi pcb assy retails around $350.00
Mar 28, 2010 | Onkyo TX-SR606 Receiver
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
HDMI "blackout" issue
There is no "self fix" your receiver is HDMI version 1.1, 1.2, or 1.2a. Has a board problem from HDMI. It can be repaired and upgraded to version 1.3b which is the current format that seems to work in all scenerios. If your receiver is still under warranty the fix is N/C. If not, call Onkyo Customer support, alot of AV receivers pre 09' have this same issue and if you raise enough eyebrows, you may be able to get it done at N/C. I know it's not what you want to hear, but that's what's happening to alot of people! Hope this helps
Aug 13, 2009 | Onkyo TX-SR606 Receiver
Listening mode functions lost one by one
It needs service. Not worth repair though.
Jun 09, 2009 | Onkyo HTR500 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Need remote control code for a sony BDP S350 blu ray player
you could try getting in touch with the manufacturers of the receiver,or if you have a code in its manual for a sony dvd,you could try that as that all blueray is,it might not matter about model of dvd.
Dec 31, 2008 | Audio Players & Recorders
Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Oct 24, 2008 | Onkyo TX-SR605 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Onkyo TX-SR606 Receiver Logo
78 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
