Question about Philips DVP3020 DVD Player
No disc error video and audio cd works only dvd gets nodisc error
    Brigadier General:
  • 3,614 Answers
Did you try to test it and play another using another disc?
You may try to clean the optical lens of the unit using a optical disc cleaner available on any electronic shop, it seems that the drive lens is dirty and can't recognize the disc inserted.
Hope this helps.
micro
Posted on Jul 19, 2009
No disc error dvd
You need to try cleaning the lens of the player. If that doesn't correct it you might have lens damage.
Jul 28, 2013 | Harmon Kardon Harman Kardon Bds 400 2.1...
Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Goodluck,
Dont forget to rate me as fixya..
Jan 31, 2008 | Hitachi DZ-MV580A DVD Camcorder
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
Sony dvp-fx750 dvdplayer is dvd disc is nodisc problem ,but audio cd,vcd runing
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Thank you for using Fixya
Sep 03, 2011 | Sony DVP-FX750 Portable DVD Player
I have a Panasonic DMP-BD80 BluRay player purchased in Australia. It cannot read BluRay discs purchased in China. Please help me solve the problem/unlock the region code. Thanks & Regards, Glenn
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Feb 25, 2011 | Panasonic DMP-BD80K Blu-ray/DVD Player
Code multiregion
here is one way:
and here is a forum whre you can get more information
http://www.avforums.com/forums/showthread.php?s=df1223ea6de85d218b01e9719ddec248&t=368649
Dec 18, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Put disc in player spins it, and says ERROR and
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say error and no disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | RCA RS2650 Shelf System
What video formats are playable on the Phillips DVP 3120?
DVP3120 can play all DVD, VCD,MP3 and Audio CD and Support the below formats
Audio Video format NTSC & PAL
DVP3120 will play CD, CD-R/CD-RW, Video CD/SVCD, DVD, DVD-R/-RW, DVD+R/+RW, DVD-Video Discs as well as MP3-CD, MP3-DVD, WMA-CD discs and MP3, WMA and JPEG Files.
Let me know if this helps
Nov 27, 2009 | Televison & Video
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips DVP3020 DVD Player Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
