Question about Toshiba W522 VHS VCR
Recording i was recording fine until i accidentally pressed something and an "L" always pops up when I try to record what is this?
    Scholar:
  • 43 Answers
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Posted on Oct 22, 2009
I have the tascam dp-02 digital recorder . It's was shutting down and I accidentally unplugged the power cord before it turned off . Now when I turn it on it just stays on a load screen . I'm wondering if...
You could try performing a factory initialization - but note that initialization of the Tascam DP-02 erases all recorded data from the drive.
To perform a factory initialization of the DP-02 turn the unit off. Hold the Up Arrow and Track Edit while powering the recorder on. You'll get a confirmation screen and then press the Yes/Enter button.
good luck
Feb 27, 2018 | Audio Players & Recorders
I have just purchased a Magnaox ZV247MG9 and to convert VHS to DVD and my first DVD is blank. All the connections are made and I followed the manual, but am confused as to what happened.
I hope you have resolved this by now but in case you haven't: The only thing I can think of is that the disc was not compatible. Make sure to use one of the discs listed in the manual.
Mar 19, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I synced a Tascam DR07 with a computer to see its files. I accidentally deleted those files from the window on the computer thinking they were copied files. They were the files on the Tascam, and now their...
You may try some recovery software to rescue the voice files on your recorder, here are some for your option.
Photo Video Audio Recovery (for Windows)
Photo Video Audio Recovery for Mac
Both programs can also recover video and audio items.
Note: Before your files are recovered, do not attempt to save more files to the voice recorder in case the original files(your recordings) are overwritten.
May 05, 2010 | Tascam DR07 Digital Voice Recorder
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
USB not saving audio. It gives CPU out of memory error.
Don't have too many folders on a flashstick try keeping everything into four folders maximum and I think you'll find it works perfectly.
Good Luck
Dec 21, 2008 | Peavey 32fx USB 32 Channel Mixer
MicroTrack Levels are off balance
That sounds like a hardware problem requiring a service. The front-case buttons are sensitive to pressure and I suspect that they go bad if stored where something is pressing against them.
May 28, 2008 | M-Audio MicroTrack 24/96
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Feb 23, 2008 | RCA RP5030 Digital Voice Recorder
Recording time
put the machine in dvd mode and press the rec mode button on the remote(right next to the rec button on the bottom) hit the button until you get to the desired mode. i just changed mine and i am copying now from vhs to dvd and it did say it is recording in ep mode, so fingers crossed!
Nov 19, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Not recording a full film
1. Insert disc.
2. Press "DVD" button on remote.
3. Press "REC MODE/REC SPEED" button.
4. Keep pressing until desired recording speed.
I believe your problem is that the movie exceeds the 120 minute limit on the target disc at the default recording speed (SP). Try LP instead.
Nov 18, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Toshiba W522 VHS VCR Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
