Question about HP LaserJet 2430dtn Printer
Tray 3 open or Empty
Hello, i am using a HP LaserJet 2430 dtn. I am getting the message 'Tray 3 open or Empty'. Can someone please help me.
Thanks
  • Qc115th Feb 05, 2009
    I have the same problem. I've tried a tray from a different printer of the same model. I've also switched out the sensor thats connected to the top half of the two parts of the printer, which the one that senses tray 3. I recieved the same error. I'm thinking that it may be the DC board but I havent tried yet.
    Problem Solver:
  • 6 Answers
While tray 3 is detachable, when I remove it from my 2430dtn the printer won't display tray 3 options in any menus, so it looks like your printer recognizes that it is there.
The micro-switches that detect "open drawer" or "no paper" in tray 3 may be malfunctioning or the electrical connector built into the top of tray 3 may need cleaning.
(or, tray 3 may be out of paper <wink>)
Posted on Dec 11, 2007
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
Replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | HP LaserJet 2430n Printer
HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Mar 11, 2009 | HP LaserJet 2430dtn Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
HP laserjet 2430 dtn little typed letters print on the left side
Probably a bad FUSER. The teflon is probably worn off.
Also take out the toner and move the drum cover aside to look at the drum..It should be clean.
Feb 17, 2009 | HP LaserJet 2430dtn Printer
2430 printing 1/2 inch marks down left side of page
Did you change the Toner cartridge? If that did not fix it :
Then the Fuser needs replacing. If you take the Fuser out from the rear, and rotate the drum in it, you will see the marks. You can try to clean it but experience shows that you will have to replace it.
Thanks, Joe
Oct 13, 2008 | HP LaserJet 2430dtn Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2430dtn Printer Logo
1,207 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
