Question about HP Officejet 6310 All-In-One InkJet Printer
The ink fades as it prints from good to fuzzy and very weak color
  • 341 Answers
Try running the print cleaning utility a couple of times , if that fails to help, remove the cartridge, fold up a piece of paper towel a bunch of times and place the paper towel in a shallow dish of water hat you don't use to eat off of and set the cartridge on the water soaked paper towel for a couple of minutes. Set the copper looking part on the paper towel. Then take the cartridge and set it on a dry paper towel that you have folded up a bunch of times but don't wipe it just blot it on the paper towel. It should leave a few black stripes if your using black cartridge or a yellow/magenta/blue if your using color. If you don't see anything on the dry paper towel then it's time for a new cartridge. If you do see either black or the three colors reinstall the cartridge and run the cleaning utility once and you should be good to go. Warning wear gloves. Ink does not come off of skin easily. Trust me you don't want to get it on your hands or anything else. Also do it on a bunch of old newspapers oir cardboard just in case something leaks Good luck
Posted on Jul 19, 2009
  • 25 Answers
Get new ink cartidges. You can only refill so many times.
  • Karen Jul 19, 2009
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
All ink very faded just changed ink too
You change with the genuine ink or not? Maybe the print head faulty or just the setting problem. Need someone assist you directly to your desktop.
May 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
Colors fading away. Replaced cartridges.
I contacted Konica M again. We ran some printing tests. It seems to be bad ink cartridges, in particular the Cyan.
Dec 21, 2009 | Konica Minolta magicolor 2480 MF...
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
HP Officejet 6310 All-In-One InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
