Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Poping noise thjere is a loud poping/tapping noise, comes on apprx half to one hour
    President:
  • Whirlpool Master
  • 1,922 Answers
If its a self-defrosting i would believe its doing its job just as intended,that is unless you have other issues such as cooling problems
Posted on Jul 28, 2009
Makes crackling noise then switching off picture green light stays on tho after half hour tv goes back on lasting a few hrs its like its overheating? if it was is this something that can be fixed?
put a towel underneath. that will disipate the sound of the cabinet poping. not overheating normal for the cabinet when cooling down to shrink and make poping noise.
Mar 22, 2011 | Televison & Video
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
Kitchen Aid refrigerator is making a very loud noise!
when you transported this unit did you lay it down or stand it up? If it was layed down then you should of waited at least 24 hours before plugging it up again to give the oil in the compressor time to settle back down. Actually either way it was transported it still needed the 24 hour rest time. So if you automatically plugged it in after transportation you could have messed up the compressor. Let it set unplugged for 2 days then plug it in and see what happens. If loud noise persists then you know the compressor is shot. Goog Luck.
Sep 02, 2009 | KitchenAid Refrigerators
Samsung RF267AABP Noise problem
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Mar 06, 2009 | Samsung RM255LASH Side by Side...
2002 chevreolet silverado makes poping noise
you may try and check any of the exhaust hangers around the cab area if you can feel it in the floor board.
Feb 24, 2009 | 2002 Chevrolet Silverado
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Loud click / tap noise every couple of hours or so
Check your owners manual for a list of common noises it should make to see if it's on that list. Does this have an icemaker? That time frame could be an ice maker valve turning on for a few seconds to fill the tray (or dumping ice).
Oct 16, 2006 | Bosch Exxcel KSR34423 Refrigerator
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
183 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
