Question about Symbol MC3000 Portable Terminal
Can i change the function of the yellow scanner on 48 keymap?
  • 47 Answers
No...for clarification, contact the Symbol Support Centre at 1-800-653-5350.
Cheers
Billy Barcode
Posted on Aug 05, 2009
Century flex 48 wiring to 220
220V doesn't use a ground. The hot legs balance off each other. The ground is for safety not function.
Jun 10, 2015 | Century Pool & Spa
After switch on, 6 sec green light, and blinking orange (yellow) light. "Cannot properl communicate with the scanner. The carriage unit may be locked ... etc "
This sounds like there is a mechanical problem inside the scanner. You may want to open the scanner to see if there is anything broken or jammed. It may need some lubrication if it has been unused for a long period of time.
Dec 12, 2014 | Epson Perfection V500 Photo Scanner...
How do i disable the f keys
Hi There,
After a few hours of research, it looks like the function or F keys under windows are pre-programmed and there's not a whole lot you can do to change it. There are, however, a few options:
Keymapping software: Usually ships with (and free to download) logitech or other gaming keyboards. The software allows you to reprogram any key on your keyboard to do what you want it to.
Hold down Fn+F11, while still holding F11 let go of Fn. Some laptop users have reported that this turns off Fn keys. Also, Holding down Fn+Scroll lock or Fn+Num lock in the same fashion has had varied results.
Jun 06, 2012 | Compaq Presario Notebook Notebook
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Why is it my scan maker 3840 having a light but it doesn't work? what should i do plz help me.... i need your help...
Scanner lights are indications of functionality where for example red is power display and green is scan in progress, yellow is indication of alternate signal once the device has been given instructions. The display of all available lights is indiction scan fucntioning. However, the device require computer connection from where the procedures of media is achievble. Scanner devices usually when attahced to computers also require softwares programs to perform as recognosed applications. Observe the computer for scanner devices program from where functions are attainable.
Feb 10, 2011 | Microtek scanmaker 3840
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
Hp colour laserjet 4600dn, 51.2Y error...how to solve that?
From Woody Friesen:
Did the printer have a rough ride? HP's service manual suggests this to be a laser error on the yellow laser scanner, though these printers usually withstand shipping without any problems. Just for grins, if you can get the printer to get to READY again, run the printer through a complete calibration (from the control panel: Configure Device/Print Quality/Calibrate Now). The DC controller circuit board is also a possibility, but given the error code popped up almost as soon as you plugged the machine in suggests the yellow scanner has suffered some sort of mechanical damage from the trip. If the calibrate routine doesn't remedy the problem and you want to be sure, you could do the major disassembly required and swap the yellow scanner with the scanner for another color in the printer and if the error code changes to 51.2M (magenta), 51.2C (cyan) or 51.2K (black) (the code will reflect which scanner you exchanged with the one in the yellow position) you'll have confirmed the scanner is the problem, or if no change, then the DC controller is next in the chain.
Dec 24, 2008 | HP LaserJet 4600dn Color Printer
Keyboard has mind of own
If you have the wrong Keymap in your Settings files the Computer cannot see and will map letters and numbers where it is told to.
Try to find the correct map for your Keyboard and set that up on the control panel /System Preferences of your Computer... C
May 25, 2008 | Computers & Internet
Battery`s dont last
Warp the batteries in few plastic bags.
Place them in the freezer for 48 hours.
After 48 hrs,it them air out for another 48 hrs,
The expand and contraction may help breaking the salt bridge.
Mar 15, 2008 | Icom IC-R10 Handheld Scanner
HP Scan Jet 3200C scanning problem
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
Symbol MC3000 Portable Terminal Logo
99 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
