Question about Bose Wave Radio
How do I connect my AWR1-1W Bose to a 36" TV. I purchased a Y-Cable (Stereo male to Dual RCA male) but cannot locate the AUX IN connector on Bose unit. Wrong Cable?
SOURCE:
djnick989
  • 1067 Answers
SOURCE: Connecting a Sony CD changer
set right input on bose 1st what cabels uuse rca in from rca out on sony
Posted on Feb 02, 2008
  • 336 Answers
SOURCE: I have purchased a samsung 46 inch LED television.
You may have to go into the bose setup and select optical in for that particular input. Check your user manuel it should say in it.
Posted on Aug 16, 2009
Ojelola
  • 22 Answers
SOURCE: I have a Lifestyle 35 and want to replace head
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Posted on Jan 26, 2010
Mustgo
  • 2361 Answers
SOURCE: Hi. I got a Bose Acoustimass
Do you have any plan to use the Bose Acoustimass 20 sub/amp in it original form?
Please double check the pins count.
Popular Bose unit has 8,9 or 13 pins.
A Bose third party vendor does sell a direct cable from the Bose Acoustimass 20 to two RCA and 1/8" stereo jack.
You can open the link HERE
Full site HERE
I'm sure you can find other cable vendor at a lower price.
I do not recommend you to open the Bose Acoustimass 20 and get the two set of wires out of the box.
It may cause damage to the casing.
On the DIN plug.
With notch / dimple facing the ground.
From let to right
1 = RED negative
2 = White negative
3 = RED positive
4 = White positive
5 center = un-use.
Please use an ohm meter to verify the resistance between1 to 4 and 2 to 4 before you start hooking up to the amp.
Please keep my posted on the project via email.
Posted on Jan 21, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a bose radio
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Posted on Apr 04, 2011
Connect my tv to my bose radio model #awrcc1
If your Seiki TV has an audio output, it most likely has RCA plug terminals (red&white). You can use a 3.5mm Male to 2-Male RCA adapter cable to connect the TV to the Aux Input on the back of the Bose Radio. The cable is less than $10.
Oct 28, 2014 | Televison & Video
How to connect bose cd player to mac mini?
You hook up a aux cable from the head phone jack of the mac min in the back to the head phone jack in the Bose cd player in the back aswell
3 5mm AUX AUXILIARY CORD Male to Male Stereo Audio Cable for PC iPod...
May 08, 2014 | Computers & Internet
I have a turntable with a connect that has a double male (large size) connector but a Base which wants a single small male to fit the AUX input. Is there an adapter I can use?
I assume you mean that the turntable uses 2 RCA output jacks and the Bose shelf system has a 3.5 mm AUX input jack. Since you have the RCA audio cable, get a RCA F/F to 3.5 mm adapter. Here is a link to one: http://www.cyberguys.com/product-details/?productid=21319&rH=1601 . If you want to just have a single cable, RCA M/M to 3.5 mm M audio cables are available, http://www.cyberguys.com/product-details/?productid=2706&rH=1095 . If you have 1/4" outputs on the turntable, you need to get a different adapter or use a combination. I don't know of many vendors for the 1/4" adapters these days.
I hope this helps.
Dec 15, 2013 | Bose Audio Players & Recorders
I have an pioneer SA-510 amplifier and i want to know how to connect it to my laptop and what kind of aux i need ? plz help
Just go to Radio Shack and buy a 1/8 male stereo cable and the other end with 2 male RCA plugs and connect them to the AUX or CD input of your receiver, the 1/8 male connector goes to your earphones output of your laptop, hope it helps.
Sep 08, 2013 | Audio Players & Recorders
Were is adio red and white for sound when laptop conects to baird 42 inch
Connecting a laptop to a tv is usually achieved by the use of an audio cable with a 3.5mm stereo plug on one end, and male Red / White RCA connectors on the other end.
Plug the 3.5mm stereo plug into your laptop "headphone" socket, and connect the Red / White RCA connectors to your PC-in audio RCA sockets.
If you tv's PC-In only supports the 3.5mm audio socket, then purchase a lead with 3.5mm stereo plugs on both ends.
Cheers
Sep 04, 2011 | Audio Players & Recorders
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
ok
Apr 04, 2011 | Bose & Wave& Music System
How can i hook up xm receiver to unit
hi,
you can connect the XM receiver to you player. for that you need a cable (STEREO MALE TO RCA MALE CABLE). its one end will looks as headphone pin and the other end 2 RCA pins.
connect the headphone pin to you XM receiver's earphone out and the other end (2 RCA) to the AUX IN 2 (AUDIO L/R)(on the rare pannel) of ur player.
select the AUX 2 input pressing the FUNCTION button on your player.
or
purchase a STEREO MALE to STEREO MALE cable and connect its one end to the earphone out of XM radio and the other end to the AUX 1 input of you player (on the frond pannel)
select AUX 1 by pressing FUNCTION button
ok
Jan 13, 2011 | Samsung HT-X50 System
What do i need to hook up ipod to bose 321. (wires etc)
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Jan 16, 2010 | Bose (321GS) System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Bose Wave Radio Logo
216 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
