Question about Siemens SX66
Freezed SX66 at the initiation Windows page
I dropped my SX66 and its battery fell out. From that time, it freezes at the Windows initiation page. I have Windows 6 installed and tried soft and hard reset without success. Any help?
    Brigadier General:
  • 3,614 Answers
This could be an internal problem on the device, cause of instant shock cause of dropping it. You better try to remove the battery for a while to reset and restore the system.
If the above recommendation did not solve the issue, try to remove the memory card, if still not working try to update the firmware of your unit.
Let me know here again for the update.
micro
Posted on Jul 19, 2009
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Tip
Deep freeze Alternatives and Similar to Deep Freeze
http://alternato.net/software/deep-freeze/
1. Comodo Time Machine http://alternativeto.net/software/comodo-time-machine/?latform=windows
2. Reboot Restore Rx http://alternativeto.net/software/reboot-restore-rx/?platform=windows
3. Toolwiz Time Freeze http://alternativeto.net/software/toolwiz-time-freeze/?platform=windows
4. Drive Vaccine PC Restore http://alternativeto.net/software/drive-vaccine-pc-restore/?platform=windows
5. Shadow Defender http://alternativeto.net/software/shadow-defender/?platform=windows
6. Returnil http://alternativeto.net/software/returnil/?platform=windows
7. FarStone RestoreIT http://alternativeto.net/software/farstone-restoreit/?platform=windows
8. Wondeshare Time Freeze http://alternativeto.net/software/wondeshare-time-freeze/?platform=windows
9. Clean Slate http://alternativeto.net/software/clean-slate/?platform=windows
10. Wioski http://alternativeto.net/software/wioski/?platform=windows
11. Safeshield http://alternativeto.net/software/safeshield/?platform=windows
12. SysFreezer http://alternativeto.net/software/sysfreezer/?platform=windows
13. Steadier State http://alternativeto.net/software/steadier-state/?platform=windows
References: http://alternativeto.net/software/deep-freeze/?platform=windows
Shadow Defender
Returnil
FarStone RestoreIT
Clean Slate
Fortres Grand Clean Slate Non restrictive Desktop Security for All Windows...
Safe shield:
Creates a visualization layer to prevent changes to the OS from becoming permanent.
/uploads/images/write_tip-crmeb11asgrdxlzgnu430hy1-2-0.jpg
SysFreezer:
SysFreezer is a utility tool designed and developed to overcome system failure. With SysFreezer installed, whenever the system has a problem such as Format, Fdisk, deleting partition or repartitioning hard disk, you only press Reset button and the system will be instantly restored to the state before the problem occurred. In this case, you can avoid re-installing operating system and application programs as well as re-configuring the system. Thus plenty of time for maintenance can be saved.
http://www.sysfreezer.com/
http://cdn.altrn.tv/s/1631ea5f-4bb6-e011-9727-0025902c7e73_5_full.jpg?format=jpg
on Nov 18, 2014 | Faronics Computers & Internet
My LG Keybo phone will freeze up when i receive a text message about 5 months ago i dropped it in water i took it out as soon as it fell in i immediately took the battery out and dried it with a hair dryer...
Alot of the LG phones have had this problem. My Keybo has the same problem and it isn't because you dropped it in water. Take it to the service place. They may need to replace it or tell you otherwise. Good Luck!
Jan 10, 2011 | Computers & Internet
Phone freeze
first try the phone using another battery, do tyr changing the unit battery make it sure it was fully charged. iy seems that you have a weak or faulty battery pack now.
Hope this initial info/idea helps
May 30, 2009 | Samsung Cell Phones
My dash keeps freezing up on the white tmobile page them on the windows mobile part ive tried holding the 2 button and the power button all it does is turn off and i tried holding the soft keys when...
first remove the battery then reinstall it, hold the 2 soft keys and the power button at the same time, do not release either, til the reformat screen appears... then press the green call button.
Apr 20, 2009 | T-Mobile Dash Smartphone
Asus laptop freezes when initializing windows after restore discs
there are 2 problems if ur windows freeze first RAM and then HARDDISK first check by replacinf RAM if it helps otherwise ur hard drive is giving u hard time try replacing it and then install OS from backup disc
i can help u more if u want
pls rate me fixya if ur problem is solved
Mar 02, 2009 | Acer Aspire 5670 Notebook
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Freezing on start up
I have had a aproblem with my digiwalker Mio, which also was freezing up. The only way to sort it is a HARD RESET. The problem in my case appears to be due to the start up program initiating GPS/Tom Tom at the same time. good luck
Aug 28, 2007 | Mitac Mio 168 Pocket PC
Freezes at system initializing screen
Please go to my blog to fix your problem. http://terminaltech.blogspot.com/2007/04/iriver-h10-freezing-at-initializing.html
Mar 14, 2007 | iRiver H10 MP3 Player
Siemens SX66 Logo
425 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
