Question about LG ALLTEL AX275 Cellular Phone
When powered on continuously reloads and does not boot all the way
I am trying to reload my operateing system w. disc that came with emachine t 5048,its not recignizing the dics,wiill read any disk but that 1???It came w. computer when i bought it. disk is perfect,no...
At power on, enter the bios (usually by tapping a function key like Tab or Del or F2) and change the boot device order to have the CD drive first. Put the disc in the disc drive. Save and continue. Now, you may get a message asking you to "press any key to boot to the CD". Touch any key, and the reload should start.
See...
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
Feb 07, 2013 | E-Machines T5048 (7136) PC Desktop
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
Lots of virus in my laptop nothing can be
Take out the battery and let set for a day and hopefully you have the start up cds for it if not you can alwasy just buy another hard drive for it
Jan 18, 2010 | Acer Extensa 5620G-832G25Mn Notebook
I have GA945GCM MOBO. While booting it gives continuous beep. If any keyboard key is pressed it stops. The keyboard spacebar key is not functioning. After boot in windows XP, the keyboard problem (spacebar...
Hi shreepad,
Those sound like you have a bad memory chip DRAM or it may not be seated correctly. The beep code of 1 long beep, also indicates a bad memory chip. If you have two or more, take one out and until you find the one that's bad. Then replace it.
Good Luck
Mark
Nov 24, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
Black/blank lcd screen after 2 seconds
try this - boot into "safe mode" - (this loads just minimal drivers). Reboot and press F8 while it's booting - it will ask if you want to boot into safe mode - say yes - if the screen works with the low resolution inherent drivers, it's probably a driver issue, or if you have a video card, it may not be able to work at the higher resolutions (which could be a card issue)
This should help you narrow down if the screen actually works, or if it's a graphics card and/or driver issue.
If it works - try reloading the driver for your graphics card (if you don't have a graphics card - try reloading both the chipset driver and the video driver from the manufacturer)
let me know if this works...
(I had a Toshiba Tecra laptop that did the exact thing - you could see the Windows boot menu, and once it completed boot up, the screen would go black - if you started it in safe mode (crummy resolution) it worked but of course the graphics are unacceptable at that resolution)
Turns out this is common with those, it was the graphic card built into the motherboard that's shot....
Oct 21, 2009 | Dell D1728D-LS VS17X Monitor
Acer Aspire One Won't Load OS
If you set it up with a dual boot, I recommend dropping in your discs and doing a repair to your OS's. Try the Debian first. I have a couple multi boot systems that have acted similarly, and when I reload the Linux Kernal, it fixes the boot record and everything runs well. If you're getting to the point that your Kernals are loading, your BIOS is fine and you're computer is passing it's POST test so the hardware is checking out. Another thing that it could easily be is your power supply. I NEVER recommend plugging in your laptop without the battery installed. Many laptops run off the battery at all times, the power supply is just continually recharging them as it's used. Giving the computer power without the battery plugged in could/would overload the circuits and voltage regulators all over the motherboard and you could EASILY damage your computer. Try swapping out your power supply with another one to make sure that isn't the issue. If neither of these attempts work (reloading the OS's/changing out the Power supply) then I recommend returning it for a warranty repair. (P.S. If you've dropped it or banged it around at all and have a traditional hard disk drive, they damage rather easily. You'll find out about that though when trying to reload the OS's. They'll tell you if it's not running properly.)
Jun 08, 2009 | Acer Aspire One PC Notebook
Toshiba a45 s121 laptop won't continue booting, help!!!
At the start of boot press F8 and a xp boot menu will appear the best way to check out what is wrong is to slect safe with networking so that if you need driver from the internet you can get them. when the computer boots look in my computer right click on property and open device manager check an see if there are any conflics which will be indicated by a red or yellow check .
If this is the case uninstall the drivers and restart the system and the drivers will reload . if there are no chechs right click on my computer and click manage go to event veiwer and look at the errors and find out when the event happen that cause you computer to malfunction and remove the drivers that were updated. all and all this sound like a device conflic. good luck...
Apr 12, 2009 | Toshiba Satellite A45-S121 Notebook
LG ALLTEL AX275 Cellular Phone Logo
93 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
