Question about Refrigerators
Water running slow out of fridge
Have changed the filter, but water still running slow. Getting slower over the years.
  • george429 Jul 19, 2009
    Just found the problem. After putting in the bypass plug, water flowed fine ==> problem in adaptor or filter. Replaced filter and made sure adaptor was on tight (needed wrench!) and things are working fine now.
  • 201 Answers
I had that problem
so when we called the repair guy
he went in back uncloged some hose part that pulled out,also he cleaned dust inbetween the tin plates under the front bottom ,sort of look like the tin things around a pipe in oil baseboard heating systems
Posted on Jul 19, 2009
Water comes very slowly from Kent RO faucet and to fridge.
If it has only been one year, check the warranty. Who said that it needed to be replaced? Oftentimes, a repairman can adjust the pressure to increase the outflow without needing to replace the whole unit.
Elisa Jed ' http://www.multicrafthome.com
Nov 18, 2013 | Culligan Under Sink Water Filter
Water is running slow
I would say you have some blockage in the line, changing the filter knocked more loose in to the line.
Apr 15, 2013 | Whirlpool Refrigerators
Slow water pressure and buzzing sound on fridge with new filter
Have you tried removing filter and reinstalling. Try that. Also sometimes you just get bad filters. Sounds like the bypass on filter housing not getting depressed all the way
Aug 18, 2012 | Refrigerators
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
I have a Jenn Air, french door style, bottom freezer. with the water dispenser on the inside left jamb of the box. there is also a ice maker. for the first 9 months every thing worked very well. then...
You have another plugged filter. That is why you ice cubes are hollow, the water is flowing so slowly into the ice maker, it does not fill up.
Recommend you install an external filter somewhere in the feeder line that connects to the rear of the refrigerator. The are surprisingly inexpensive, compared to the filter inside the new 'fridges. I recommend you buy a replacement external filter cartridge at the same time you buy the external filter kit. Of course you will need to change the internal filter one more time or bypass it per any instructions provided with your fridge.
Aug 11, 2009 | Refrigerators
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
LG SIDE BY SIDE - REPLACED FILTER BUT WATER VERY SLOW
You may have ice building up inside the fill tube that is slowing the water flow.  You will have to remove ice maker to see inside the tube.  If the tube has ice buildup, use a hair dryer to melt the ice.  Then is should work fine.
May 23, 2008 | LG LRSC-26922 Side by Side Refrigerator
Amana SZD26VW about 10 years old - no water or ice
probaly the water inlet pump behind the fridge is defective or the filters are clogged I'd change the filter first if this dosen't help i'd say change the water inlet pump
May 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water Dispenser and Ice Maker
Have you checked the pressure limiting valve which protects the filter from over pressure? It could be blocked/faulty. Have you checked the inlet on the valve assembly? It may be clogged up. Try bypassing the filter all together to determine if the filter is faulty.
Oct 29, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
304 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
