Question about D-Link AirPlus Xtreme G DWL-2100AP (DHDWL2100AP) 802.11b/g Wireless Access Point
I have a dwl-2000ap, the problem on the lan port does not function, led indicator lan does not work. I have input cable type Straight-Through or crossover, but it still does not function whether dwl-2000ap my fault. can be improved? help me please
  • 341 Answers
So your hooked up from your cable company to the modem and from the modems ethernet connection to your computer. If all this is good , and it doesn't work, I know in the past I had to call my cable company and give them the mac number off of my modem in order for everything work properly. The modem Mac Address is usually posted on the bottom of the unit. Hopefully this will help out, Good Luck
Posted on Jul 19, 2009
    President:
  • 1,383 Answers
Check your lan cable is correct crimping also try to other ethernet cable.
Reset your router settings.
You can reset router with reset button .
It is in back side of router press it for 15 seconds.
Aslo check your lan card with which yhou connect ethernet cable from router it should we working fine.
Also try to uninstall ethernet driver then reinstall.
Check in another computer lan port.
Thanks for using fixya.
Please rate this solution if it helps you.
  • 630 Answers
It should work with either cable. The LED will only come on when a connection is made to the computer or router. Is the LAN adaptor working correctly at the other end.
According to directions I need to leave password area blank, but I keep getting an error "the password is error"
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 11, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
My dlink air plus in not working, but all the lights are one including, power, lan and wireless lan.......................
Try RESETTING the D-Link.
Press and hold the RESET button at the back of the routerwith the power ON until the LEDs flash at the time the release the RESETbutton.
http://192.168.0.1
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 06, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
LED for WLAN doesn't turn on, no wireless signal
ok now connect the laptop thruh lan and try to open router configuration...check ther wther ur wireless is on.....or try to reset your router ...and cross your laptop with othr router,reply
Mar 17, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
Jan 24, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Network with two D-Link DWL-2000AP
Yes,If it is all on one network. That is the same IP scheme and Gateway.
Just set up a Home Network and give permission for all the PC's to access your "server"
No need to buy anything, just go into the Control Panel, Network Setup Wizard.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus Xtreme G DWL-2100AP (DHDWL2100AP) 802.11b/g Wireless Access Point Logo
274 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
