Daytron All in one Turntable, 8-track & fm
Daytron All in one Turntable-33rpm/45rpm, 8-track & fm radio; trouble with turntable:
The Turntable plays slower than it should. i have looked all over the entire thing inside and out (literally and there is no variable resistor or any sort of thing like it) and i need to find how to speed it up. i dont have a manual or schematic. i have searched far and wide on the web for one or even the company site but nothing helps. need help bad and plead for it. please help if possible before i loose my mind. thaaaaaaaaaaaaanks! and i have no model # as it is not posted on the item anywhere on the unit. :)
  • 35 Answers
If the turntable is belt driven.... try replacing it... maybe the belt is worned out
Posted on Jul 19, 2009
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Technics 1200 mk2
Sounds like a short on the pcb, one of the IC's could have gone bad, or the 33/45 have shorted out. Unless you have the proper tools i can only direct you to who you could send it to or order the part(s) from. If youre good at soldering and can work in square inch spaces, go for..
http://www.djproaudio.com/cgi-bin/Help/pdesk.cgi?do=get_download&id=2&filename=MK2_cabinet.jpg
http://djproaudio.com/Store/advanced_search_result.php?keywords=Technics
http://djproaudio.com/Home/
Keep me posted.
Nov 18, 2007 | Technics SL-1200MK2 Turntable
93 people viewed this question
 Grubhead
Grubhead
