Cell Phones Logo
Mister allen Posted on Oct 17, 2016
How do i enable usb debugging on my lg306g - LG Cell Phones
1 Related Answer
boneman1975
boneman1975
  • 187 Answers
  • Posted on Apr 21, 2016
SOURCE: How to Enable USB Debugging on Xiaomi Mi 5/4/3
Go to settings and look for device info or about device or similar. then look for build number and tap it 5 times to enable developer option. Go back to settings and you should see it. This is for all Android phones doesn't matter what brand.
How to Enable USB Debugging on Android with Black Screen?
USB debugging must be enabled in order to perform actions on your phone from your computer. This guide takes a look at how to enable USB debugging on Android with broken black screen using a couple of different ways.
- Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command
- Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse
- Part 3. How to Recover Lost Data from Android with Black Screen
**Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command**
One of the ways to enable USB debugging on your Android phone with a black screen is to use an ADB command. There is a command that you can use with ADB toolkit and that should help turn on the USB debugging option on your phone.
The following describes how to enable USB debugging on Android with black screen through computer.
- Download theADB toolkitfor your computer and extract its contents to a folder.
- ADB requires you have USB debugging enabled on your phone. Since your phone has a black screen, reboot your phone into recovery mode to accomplish this. Press the Volume Down and Power buttons at the same time to enter recovery mode.
- Connect your phone to your computer, open a Command Prompt window in the ADB folder, and type the following command.
adb devices
- You should see your device listed there. Run the following commands one by one.
adb shell
mount data
mount system
- Use the following command to pull the persist.sys.usb.config file from your phone to the PC.
adb pull /data/property/persist.sys.usb.config C:\Users\\Desktop/build.prop" /system/
- Reboot your device using the following command.
adb reboot
You are all set. Your phone will boot up with USB debugging enabled.
**Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse**
If your phone has support for OTG, then you can actually plug a computer mouse into your phone and use it to navigate around on your device. This way, even if your phone has a dysfunctional black screen, you can still perform various actions on your phone. The following shows how to enable USB debugging on Android with a black screen using a mouse.
- Connect your mouse to your Android phone using the OTG. Make sure your phone supports the OTG feature.
- You will probably need to mirror your phone's screen to your computer, if you cannot see anything on your phone.
- Use the mouse to head into Settings > About phone > Developer options and tap on the Build number 7 times to enable the Developer Options.- Back to About phone section and you should find the USB debugging option. Click on the option to turn it on.
USB debugging is now enabled on your device.
Enable USB debugging on broken zte phone
If the software is for any Android phone it would probably work.
2answers
1helpful
HOW do I get to debug mode on Samsung note 10.1 2014 edition p 605?
go to About phone then press the Build number 5 times, like that the devlopper option will be activeted than go back & entre it and enable USB debuge
1helpful
How can i enable usb debugging for pioneer r1?
Generally, to enable hidden developer features in Android (like usb debugging):
Go to Menu-Settings-About device
Tap on "Build number" multiple times. You should start to see a message that says something like "Tap 3 more times to enable developer mode" and so on until it says Developer mode enabled. You should then have a Developer options selection available in your menu that includes a USB debugging option.
My Screen Is Blank But I Can Still Click Stuff On Phone I Need To Enable USB Debugging
Michael
Without being able to see it will be extremely difficult to do as there is scrolling.
Mark
Motorola Support
How to enable usb debugging acer a510
I finally found it myself after looking for hours and testing.
Go to settings -> Options for developers -> Right top corner, turn it ON -> scroll down to debugging -> USB-debugging -> click it.
Enable usb debugging
This is not an android device so it will not have USB Debugging
Not able to connect wildfire with pc. its shows no device connected downloaded latest software for HTC sync and check found the same. Kindly suggest.
enable usb debugging in menu>settings>apps> then the last option (i don't know what it is in English because mine is in dutch) >check usb debugging
also: i recommend formatting the sd card
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
