Refrigerators Logo
A
Anonymous Posted on Oct 17, 2016
Samsung RS2544SL/XAA getting iced and freezing
Babar Ameen Khan
Level 1:
Habit-Forming:
New Friend:
  • Contributor 21 Answers
  • Posted on Oct 17, 2016
Babar Ameen Khan
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
21
Questions
Helped
9977
Points
62
In freezers if it's getting ice inside body surface? Sometimes refrigerators doesn't defrost ice completely and shut the drain water line of defrosted ice. If you doesn't have checking instruments for defrosting heater element and other parts, there id's wary wary to defrost ice once completely once. Thank you
  • Babar Ameen Khan
    Babar Ameen Khan Oct 17, 2016
1helpful
The ice maker line freezes. I have thawed it, gotten water flow and one set of cubes but the line freezes again before in the time it takes to freeze the first set of cubes. What should I check next?
Check the water pressure or any filters in the water line or a crimp in the supply tube. Also make sure you totally defrost where the water enters the ice maker.
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Freezer freezes food, but why is ice cream melting?
Hi
It would be helpful for the model as some samsung models are single cooling and some twin cooling,please supply the model and i will be able to help.
Bryan
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
2helpful
MODEL RS2544SL NOT COOLING
Do you see ice on the back wall of the freezer?
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
4helpful
3answers
The model is a Samsung RS2544SL and the BOM Name on the tag is RS2544SL/XAA The frige and freeze do not stay cold. The ice door keeps making a clicking sound and the fan (but not compressor) keeps...
ON THE FRONT DISPLAY THERE SHOULD BE A FAULT CODE. IF NO CODE YOUR MAIN BOARD (ON THE BACK OF THE REF.) IS BAD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
17helpful
4answers
Two issues
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
