Question about Boss Car Audio & Video
I need installation guide how to fit the boss
I need installation guide on how to fit the boss power amp ba-2900 on my car.....thnx
2 Suggested Answers
  • 3 Answers
SOURCE: Boss BA-2900 car amp doesnt produce any sound
i have come across a similar problem before. if you are using the ceramic (glass, clear) fuses the solder in the end caps sometimes melts. you will not see the fuse blown, but the fuse may still be bad. try a new fuse to see if that works. also make sure no single stray strands of wire from a positive or negative wire are touching on the terminals on the amp. i hope this helps. ill keep thinking of other things in the meantime
Posted on Jan 06, 2009
What's the watts for a boss audio systems BA-1200
Here is the manual with all the specs for the BASS1200 10" Low Profile Amplified Subwoofer
http://www.bossaudio.com/manual/index.php?dir=&file=BASS1200_EN_UM.PDF
Sep 16, 2015 | Boss Car Audio & Video
How to install boss 612ua in 2004 dodge stratus
Have a wiring harness for your vehicle if not get one and have a dash kit that fits your vehicle now plug the new harness into the plug that came from your stock radio now match all the wires from the stereo to the harness twist and tape if you can't solder also may need an antenna adapter to fit your new stereo all wires should be labeled and it's ok if there are a couple you don't use
Jan 31, 2014 | BOSS AUDIO SYSTEMS 612ua
High pitched noise coming from speakers after installing stereo
you may need to use a power line noise reducer or if useing amps a rca line noise reducer
May 10, 2010 | Boss BV9560 Car Video Player
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Hi looking for a manual for a boss ba-1000 car amp
You can contact boss electronics or the amp retail store.. Most boss amps are sold at flea markets so they may not have direct access to the Manufacture. look at your amp and see if there is an 800 on it if not contact the place you bouht it for a phone #
Nov 02, 2009 | Car Audio & Video
I need to know how to install a Boss Audio
Hello viperman2004,
Just connect your speaker leads to the input of the B65N (gray and gray/white pigtail leads), run the RCA cables to your amp (red=right) inputs, adjust the left and right level controls to match the amp input without distortion, and mount the unit.
Hope this helps.
Aug 11, 2009 | Boss Car Audio & Video
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Having trouble with BOSS BA-2900 car amp, anyone knowing anything about...
There's your problem. Boss is garbage, you get what you pay for when it comes to car audio.
Jan 05, 2009 | Car Audio & Video
Jan 05, 2009 | Boss Car Audio & Video
Wiring up amp/installing amp
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Apr 04, 2008 | Car Audio & Video
Car Audio & Video Logo
380 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
