We were able to hit the drain button and empty before we cut the power off. Obviously something in the control board shorted.
SOURCE: Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
SOURCE: Maytag Quiet Series 300
Sounds like a thermal fuse that is a less than $20 part. remove the top 6 screws in the door that hold the plastic front panel on. Behind that is a circuit board and a white flat 1" square fuse with two wires going to it. make sure power is off at breaker. Test with an meter to see if any current is going thru. If not, that is most likely your problem, and just follow the fuse replacement kit instructions carefully, including putting the new wires on the new fuse like they say. Otherwise, the original wires going to the fuse will blow it too.
Should take about 20 minutes.
SOURCE: maytag dishwasher jet clean eq plus water not filling
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
SOURCE: Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
The
most common causes of this problem are a defective water inlet valve or
a stuck float switch. The float switch sits under the dish racks and
sends a shut-off signal to the dishwasher when the water level is high
enough. Make sure you only use a Maytag-compatible replacement if you
have to change out your dishwasher's float switch or water inlet valve.
Difficulty: Moderate
Instructions
Things You'll Need:
